Results 1 to 7 of 7
Thread: Mini Pajero Mechanic - Isb/RWP
    aabbasi007's Avatar
    Feb 2007
    37
    416
    Default Mini Pajero Mechanic - Isb/RWP
    Guys,
    Who is the best mini pajero mechanic in islamabad/rawalpindi ? Urgent help would be appreciated.
    Regards,
    Subhan-Allah-e-Wabihmadihi Subhan Allah il Azeem.
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    what sort of work Mini needs? every task has its own specialist.
    aabbasi007's Avatar
    Feb 2007
    37
    416
    I am getting a strange sound from the engine bay... want to get it checked...
    I want somebody who is an expert in mechanical stuff, specially related to engine...
    kamran.awan's Avatar
    Jan 2013
    34
    82
    2 Post(s)
    Aoa,
    I have smoke in my Mini Pajero Engine. Its also missing on starting. Checked from many specialists but no one have its solution of missing.
    arzaam.bhatti's Avatar
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    Quote Originally Posted by kamran.awan View Post
    Aoa,
    what engine oil are you using, its common for mini to do that on heavy viscosity oil like 20W-50. use 10W-40 and it wont do it.
    what type of smoke you have from exhaust, blue, white or black?
    If everything is coming your way, you're in the wrong lane!
    Jan 2013
    34
    82
    2 Post(s)
    Quote Originally Posted by arzaam.bhatti View Post
    Its blue smoke
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    Its blue smoke
    Blue smoke means engine is consuming oil
    Get compression test , probably your engine is weak and that's why it has trouble starting, valve seals maybe on the way out,
    To counter a problem of oil consumption you will most likely be using a heavy weight oil which will in turn cause missing at cold starts
    Also check if you have proper ground and voltage, get a grounding lot of neccessary, my mini once suffered from this missing at startup due to loose negative on body and there was a resistance to flow on start which caused improper voltage to spark plugs and misfire
    Sent from my iPhone 6Plus using PW Forums
