Results 1 to 5 of 5
Thread: Mini Pajero Idling Problems!
    nakhter's Avatar
    Jul 2007
    42
    14
    Default Mini Pajero Idling Problems!
    Hello all, I hope that someone can help. I have a 1995 Mini Pajero and it sometimes dies while idling especially when comming to a stop from about 50 KMph this happens both on CNG as well as Ptrol. I have gotten it tuned and even the throttle taken apart and cleaned but no help. The jeep RPM comes down to about 1000 then shudders and drops till the engine is dead when comming to a stop. I think it might have somethign to do with the throttle control motor would love any inout or insight into this problem. Has anyone else had this problem? What did you do to fix it?
    Thanks!
    Make a Difference use your brain!
    pooochieee's Avatar
    Nov 2005
    37
    84
    increase idle speed and check for break booster problem.
    nakhter's Avatar
    Jul 2007
    42
    14
    The idling speed is already at 1200 RPM I will definately have the brake boster checked. BTW is does this even when parked now all I have to do is rev till 5 - 6000 RPM and hold the clutch and the engine dies.
    Thanks for the input.
    gunshippilot's Avatar
    Aug 2006
    43
    610
    Flying is my passion.
    SMARTDEVIL's Avatar
    Oct 2006
    36
    242
    10 Post(s)
    I had a similar problem with my dads Civic but that was caused by its security switch/ CHOOR SWITCH
    have the electritian check the circuit !
    Thanks & Best Regards Mustafa Parveiz
    (Cell: 0300-6620420 ) www.pakistanbikersclub.com
