Results 1 to 8 of 8
Thread: ]]]]]] GEAR OIL QUESTION <<<<<<
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Default ]]]]]] GEAR OIL QUESTION <<<<<<
    Hello all off road & vintage vehicle owners.
    I have a question for all those using vintage / veteran jeeps like the Willys or Ford
    WITHOUT
    altered differentials & gear boxes.
    What gear oil do you guys use in your tranny & differentials & have you ever had any problems with it ?
    The reason to ask you all is that I cannot find a straight mineral gear oil that is required for older vehicles, as some components are made of bronze & copper in the tranny and diffs & the EP oils available in the market have sulphur that attacks these yellow metals and eats them away.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    @aamir567 can be of some help cause he got 1942 willys all stock.
    Still Play with Mogs... DeeMog 421.129 1986... http://www.youtube.com/user/DeeMog421
    http://www.pakwheels.com/forums/4x4-clubs-off-roaders-suv/87109-team-unimog-punga-project
    Dec 2007
    40
    1,599
    Thanks DeeDee,
    What do you use in your Mog, since it was recently overhauled ?
    Are you a member of any dedicated Mog Owner's forum ?
    Here's one, www.benzworld.org/forums/unimog/ for any and all information.
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    as mine is stock as well, (not the electric and interior) here it is:
    Main transmission, PTO, axles and wheel hub=SAE 90 caltex (year-round). 9ltrs total
    hv not tried benzworld but m a member of mog-owner.tx4x4
    cheers
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    I have a Willys M38 and it has Caltex Thuban in tranny and differentials. Thanks God, no problems so far!
    awanfarooq's Avatar
    Apr 2009
    Rawalpindi
    46
    20
    you should allways use caltex gear oil 140
    Dec 2007
    40
    1,599
    h2@awanfarooq: sir jee, what is the name of the oil ? Caltex has Thuban EP90. Have not seen 140 grade. Which one are you refering to?/h2
    NoWorNeVeR's Avatar
    Dec 2005
    36
    832
    4 Post(s)
    M 151 with 2C, (Original Gear and sifferentilas)
    Gear Oil Warco with one STP
    Differentials STP
    B all U can B
