Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree3Likes
Thread: Advice Needed Max Tire Size, Landcruiser 80 Series
    farazarif's Avatar
    Dec 2007
    1,153
    17 Post(s)
    Default Advice Needed Max Tire Size, Landcruiser 80 Series
    Hi guys,
    I need some advice,
    I have a Toyota Landcruiser 80 Series (91 through 98) and need to replace my tires,
    Im thinking of up-sizing the tires to improve clearance, I have a 2" Lift kit installed but due to the length of the vehicle it still sometimes rubs its belly on steep hill ascents and rocks during offroading,
    Could someone please advise me on the maximum tire size I can go for without having to do any other adjustments like panhard rods / control arms / castor correction etc.
    The rim size I will be using is 16" and the stock tire size is 275 / 70 / 16 but I'd ideally like a little more lift without going ridiculously big.
    Any advice would be really appreciated.
    "A car is just a car unless it's my car" - Faraz Arif
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @farazarif
    OEM....always!!!
    MEN DO IT AT DAKAR!!!
    farazarif's Avatar
    Dec 2007
    1,153
    17 Post(s)
    Thanks Mitsu-man, it seems like thats what I'll end up getting...B-)
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    OEM size is ideal, but if you want small increase in height, just enough so it doesn't affect the gearbox and clutch load, you can try the following for comparison
    275-70/16 has height/diameter of 31.3inches
    265-75/16 has height/diameter of 31.8inches
    235-85/16 has height/diameter of 31.9inches
    285-75/16 has height/diameter of 32.8inches
    The last one probably would put considerably higher load and increase consumption. Also tyre choices will be limited in it.
    Finally the speed ratings availability is also limited with non-oem sizes. I recently stayed with 275-70/16 size as that had highest speed rating available (more safety margin)!
    Good Luck.
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    @nn what is the height/diameter of 315-70/16?
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
    farazarif's Avatar
    Dec 2007
    1,153
    17 Post(s)
    @ Jeepaholic,
    315 /70 / 16 would be 33.4 inches tall and the sidewall would be 8.7 inches creating 605 revs per mile.
    @ Mitsu_Man
    I ended going for the new set of BF Goodrich as you suggested, it just eats up the little lumps and bumps on the road like no body's business, a seriously awesome tire, I didnt think I'd say this but its even better than my pet Yokohamas! The shoulder is very flat and aggressive which gives a strange feel on cornering or very uneven tarmac but I guess that will just take getting used to and granted the Goodyears I was using were old and tatty but these things literally have more than twice as much tread depth, Ive married them up with Centerline 8.5 depth rims so it opens up the tire nicely, Can't wait to try them out this Sunday in the rough stuff. I was also expecting some tire noise with such an aggressive pattern but there's virtually none.
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Quote Originally Posted by farazarif
    I apologise if this is slightly off-topic, but have you considered rock-sliders or skid plates? They might give you some peace of mind when tackling the really rough stuff, because even if the tyres are slightly bigger you'll still end up grinding its underbody parts.
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    we are also running stock sized BF Goodridge tyres on our HDJ80 and no other tyre has performed better overall (have tried pirellis, yokos, michelins etc.
    BF's were the cheapest too(Y)
    farazarif's Avatar
    Dec 2007
    1,153
    17 Post(s)
    @ Storm
    I totally blew my budget with the BFGs but they're def worth it
    @ sami_voodoo
    I have considered all the under body armour but have not installed much of it as yet, thats the next phase of the project, I have installed diff guards and will be installing skid plates in Sept Inshallah.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    you shoudl also consider rock sliders, they were a god-send in my defender.
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @farazarif
    Now thats the second wisest thing you've done.....suspension being the first( wipe that grin off your face amigo....buying the TLC won't make you move any notches up my stock....heheh). You won't regret this leap. Taken care well they'd last you a 100.000 kms......the traction, grip, reliabilty are a plus.....are the best of the best!!!
  12. #12
    HasaanIqbal's Avatar
    Mar 2009
    Khewra
    43
    74
    @ Jeepaholic
    for tyre sizing knowledge and comparasion
    go to google
    type " tire size calculator " and go to any of the numerous sites..
    U will get all the answers
    TC
  13. #13
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Ironman Coils & Foam Cell Shocks
    (NO LIFT KIT OR SPACERS)
    Yokohama 315/75 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188290
  14. #14
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Michelin 325/85 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188291
  15. #15
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Michelin 325/85 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188292
  16. #16
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Michelin 325/85 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188293
  17. #17
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Yokohama 315/75 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188294
  18. #18
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    80 Series with Stock Suspension
    275/70 R16
    80 Series with Iron Man Suspension (NO LIFT KIT)
    315/75 R16
    Advice Needed Max Tire Size Landcruiser 80 Series -1188295
  19. #19
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Quote Originally Posted by farazarif View Post
    Hi guys,
    I need some advice,
    I experienced the same problem, even after installing an Ironman Suspension which gave me an extra 2 to 3 inch lift (NO SPACERS OR LIFT KIT)
    The differentials would mostly get rubbed on bigger stones or pavements
    But after I changed the tire size from 275/70 R16 to 315/75 R16
    the problem was solved and the articulation is also good
  20. #20
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Quote Originally Posted by orange17 View Post
    But now I have changed the tire size from 315/75 R16 to 285/75 R16
    Because the 315s were way too wide (THOUGH THEY SEEMED VERY COOL) and they were affecting the vehicles pick on road, and also they were too heavy & wide for the suspension while articulating & going on bigger rocks & especially when the vehicle bogged down in deep mud .. (they would get stuck because of being too wide & heavy)
