Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 124
Thread: Petrol vs Diesel - Toyota
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Default Petrol vs Diesel - Toyota
    Having been out and about in my 4.0L petrol a few times now, I am still a little confused over the benefits of diesel vs petrol in 4x4s. As i understand, diesel engines have a huge advantage over petrol engines where the terrain has a lot of water. Are there any other advantages?
    Someone commented the other day that the diesels have more torque, which translates into more power off road. I don't totally agree with that. A true 4x4 low speed (range) petrol engine will have equal, if not more torque. Am I wrong in assuming so?
    Lastly, what is the performance of a diesel 1KZ-TE engine in a 4x4 like mine? Would it perform better than the original 3F in my RKR?
    RKR.
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
  2. #61
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Rao,
    Yes, put silicon on the botton inside crease of the boot and on top of the boot where the cable goes through. This should do the job, if you want to do the spark plug side too then use non-melting grease and NOT silicone.
  3. #62
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    ^^^ Thanks for the heads up, I was about to use silicone for the plugs part too!!! Plugs aren't that big an issue, it's the distributor that's the culprit mostly.
    RKR
  4. #63
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    ^^ Based on my tiny miny experience, silicon works best! I seal the distributor using silicone and it has never let me down whenever I "wash" the engine bay now :p
    https://www.facebook.com/OsamaAbbasPhotography
  5. #64
    R.I.P. Follow
    topracer's Avatar
    May 2006
    36
    2,652
    bhae decide and conclude the debate quickly, i am waiting for swap, also confused between 1kz and 1fz-fe
  6. #65
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    ^^^ what 4x4 do you want to put the 1kz or 1fz in? What's the 1fz costing you?
    RKR
  7. #66
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Quote Originally Posted by raohamid
    ^^^ Thanks for the heads up, I was about to use silicone for the plugs part too!!! Plugs aren't that big an issue, it's the distributor that's the culprit mostly. RKR
    Let me know if it works, there is also another way to seal the distributor cap if this not works but i won't be disclosing it here.
  8. #67
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    ^^^ okay, always a treasure in there with you Sherwan! Just waiting for the rain.
    RKR
  9. #68
    usama37's Avatar
    May 2008
    Gojra
    31
    282
    5 Post(s)
    can ne1 tell me how much 1fz-fe wud cost?
  10. #69
    aark30's Avatar
    Nov 2008
    Peshawar
    38
    1,200
    2 Post(s)
    2 Thread(s)
    deko bhai ager pani mai ghoataa i mean dobkee laganee hai to diesel to werna petrol but i suggest you diesel its less problematic in offroad and remember simple the better 1kz ideal hai ." SOOCH GEHREE HO JAI TO IRADAY KAMZOR PER JATAY HAIN "
    THE Word Impossible is in the Dictionary of Fools!
    "4x4 are built NOT bought"
  11. #70
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Making it more simple.. Diesel khappay
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  12. #71
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @RKR
    Bud, forgive me for missing out on this INTERESTING thread (it said TOYota....solid reason to stay away eh??).... but after going through this, I am willing to shoot myself (only in the foot if you insist)!!! Keeping rallying apart (which is fast becoming a FILTHY rich man's sport here) and focusing on the off-road pranks that we undertake.....this thread has answered most of my worries as I was a bit dicey on replacing my faithful 4D56( parked in Isloo and used for touring North with ORAD) with a similar gen 6G72!!!!
    Humbly put.... does smell very nice once you fire one up....especially on a cold morning with that steam/water thing from the tail pipe!
    The power/torque/BHP....anyday better (in comparison to my poor ol' 4D56 only).
    Gasoline IS getting cheaper!!!
    Even if I am unlucky (and lucky enough to keep the electrics out of the equation) to suck up water in my engine while fording, don't need an overhaul......diesels are notorious for bent rods, ain't it so????
    Lesser pit stops for oil/filter changes.
    No vibration/hum.....best of the best diesels have 'em!
    Though it ain't no V8 but still love that 'V' growl (no grunts) when you floor it.
    My mind is all set.....RAO, gasoline is it....stick to yours!!!
    @JANJ.....you've got it all RIGHT 100%.
    MEN DO IT AT DAKAR!!!
  13. #72
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Mitsu_dude
    Aarghh!!! A rip-snorting, smoking, whistling turbo-diesel is what should be under a 4x4s hood. On a practical note, a tweaked and turbocharged 4D56 might be able to match the 6G72 on power (around 160-ish BHP), while surpassing it on torque. The catch? The 6G wouldn't break a sweat while the 4D would be at the limit of popping its headgasket and melting its turbo. Not to mention the fuel consumption of such a modified and over-fueled diesel would be on par with the petrol.
    All that being said, I'll stick with the diesel on a 1st gen, cuz I'm a pedantic, and I've spent (read: wasted) too much of my time on diesels to do anything with petrols.
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  14. #73
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    You are the TECH guy here but I'll try and make it look easy to tweak up the 4D..... that new TRITON(L200)....chip her up and voila.....the 6G is in a lot ot trouble just to keep up.....simple???? No meltdowns or mega fuel bills, amigo!!!!
  15. #74
    Sep 2004
    35
    3,701
    8 Post(s)
    Now that's a thought, a chipped, new Common Rail 4D56 in the 1st gen Paj
  16. #75
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    The motor, ECU, wiring harness and the chip itself is gonna cost you twice the price of that MK 1 'jero.....and keeping in mind the never ending technical glitches pitched by the local USTAAD Gs (plus their formidable fee), I think I am much better off in my stock 6G72, amigo!!!!
  17. #76
    Sep 2004
    35
    3,701
    8 Post(s)
    A Mk 1 Paj with a straight through exhaust and an unsilenced airbox on a 6G72 sounds fruity... 150-odd BHP should mean 10 second sprints to a 100 k's as well.
  18. #77
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    RAO is going to shoot me for sure for turning his thread into another PAJERO affair (though I think he still owns that 4M40 shogun....so bear with us amigo)....... Yes I've been experimenting on one of the three 6G72s I have (the NO-tomfoolery 6G74 is still parked happily).....the one with a manual shift SWB is in the focus....the cat has been removed, bigger dia pipe and single free flowing exhaust .....besides notable change in the muffler note there is some improvement in performance.......of course no major differnce in Gs..... idea being to change the rally category and run her against the 3.0 (1 KD)vigo.... I know it sounds rather too wishful but I've tested her against one and there is a cars length difference till 150 and that's not too bad!!!! Searched the net for a supergharger but it is available for the DOHC and not for my SOHC 6G72....besides they might bump me up to the OPEN class for that (it'll be difficult to match EVO even then.... with still a 100 horses short and without the IRS )....Is there any CHIP option that you know of???? I know chips for gasoline engines are rare to find!!!!
  19. #78
    Sep 2004
    35
    3,701
    8 Post(s)
    I was just looking through the specs for the 6G72 on the Paj, and it seems to be of the 12 valve SOHC variety. As for power, it's half that of the EVO (143-158 BHP). I'm not sure you'll pick up anything meaningful with a chip. 10% maybe? Have you looked into the 24 valve 6G72s from the Galant? They've got around 200 BHP.
    As for the supercharger kit, i'm sure you could adapt it to fit, but the piggyback controller that comes with it might be confused with the potentially different ECU maps.
    I think it should run favourably with the Vigos. It's a lighter car anyway, although as far as the torque is concerned, you're in a playgroup compared to those big guys.
  20. #79
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    Your input is always valuable dear....and you are spot on the torque mismatch I am likely to face in that category against the 1KDs!!! Shedding some serious weight might do the trick as already mine is a lighter truck. And that 10% with that chip might make the world of difference.....start snooping, amigo!!!
  21. #80
    Sep 2004
    35
    3,701
    8 Post(s)
    Mitsu_dude
    Looking on the bright side, you can rev your engine higher than the 1KDs. So you can hang on to gears longer. I'll see what I can find on the chip. Oddly though, the few I've seen are designed to reduce fuel consumption...
