Results 1 to 14 of 14
Thread: Want to change the engine of Prado 1999, plz help.
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Default Want to change the engine of Prado 1999, plz help.
    Hi all, my nephew wants to change the engine of his Prado 1999 LWB which presently has a 3L (which is sluggish) with manual trans. Kindly discuss the pros and cons of all the avilable choices Diesel/Petrol. The purpose is to get more "ONROAD" power out of it. I would be greatfull if you can give prices also.
    Thanks
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    @ Jeepaholic............ if it is a 99 prado then it must have come with 1KZ or 1 KD. if he has worn out any of the above i would suggest he go for 1 KZ. it is a very tough engine and can take the beating here in Pakistan on and off road.
    1 KD is a troubled engine.....avoid it.
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Thanks desertdevil this one came originaly with this 3L engine as all the basic models of prados came with it, all the premium models came with 1KZ like your's one. What trouble can 1 KD cause please elaborate. And what about the petrol engines?
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Want to change the engine of Prado 1999 plz help -966586
    Want to change the engine of Prado 1999 plz help -966587
    Want to change the engine of Prado 1999 plz help -966588
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by jeepaholic
    The new petrol engines that come in the latest shape is awesome. The 4000cc one. The 3400cc is no slouch either, but i would stear away from all 2700 vvti and non vvti engines.
    RKR
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    @jeepaholic
    1KZ-TE will fit on original mount, no alteration!!!!
    The 1KZ-TE is a 3.0 L (2982 cc), 4 cylinders, SOHC, 3 valve per cylinder turbo diesel engine. Bore is 96 mm and stroke is 103 mm, with a compression ratio of 21.2:1. Maximum output is 130 hp (97 kW) @ 3600 rpm with maximum torque of 29.3 kgf·m (287 N·m) @ 2000 rpm. Redline is 4400 rpm. First produced in 1993, 1KZ-TE also adopt the electronically controlled fuel injection, ETCS-i (Electronic Throttle Control System - intelligent) technology which is similar in basic construction to a modern gasoline injector, although utilizing considerably higher injection pressures, making it a very efficient engine.
    Price Lahore 80000
    ECU 10000
    Wiring Harness 10000 Approx
    Radiator 22000
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    might help you
    http://en.wikipedia.org/wiki/List_of_Toyota_engines
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Bro if u want to go for diesel then go for 1KZTE with electronic throttle .its little bit higher in price than a regular one but definately worth it. smoother ، more responsive engine and faster offcourse
    Drive a Legend. Drive a Land Cruiser
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    my friend bought a UN auctioned prado with 3L
    pick and torque was awesome but
    it refused to cross 120km/hr on motorway
    thank god he sold it
    and i agree with the rest. 1 kz (though it will be a bit fuel thirsty but.....sawad ay ga )
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    How do your compare 1KZ TE to 1 GR FE? please give your input.
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    that is a killer engine but might require alot of work . It will be a beast if done the proper way
  12. #12
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    from transmission to drive shafts to exhaust everything
  13. #13
    HummerH1's Avatar
    Dec 2006
    20
    183
    Any idea about the possibility of accommodating 1UZ-FE in this Prado? I mean does the engine bay ?????
    In ma village offroad starts frm ma porch!
  14. #14
    M
    M is offline
    M's Avatar
    Mar 2008
    86
    132
    http://www.sohcmydohc.com/2009/07/my...vs-350z-740li/
    hows this ?? lemme knw if u r interested in the 1UZ
    http://www.sohcmydohc.net
