Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: 2KD INJECTORS
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Default 2KD INJECTORS
    NEED USED OR NEW FUEL INJECTORS FOR TOYOTA 2KD ENGINE.
    NEED THEM IN A HURRY! PLS HELP.
    SAJID
    Pakwatan Explorer
  2. #21
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Quote Originally Posted by MITSU_MAN
    @sami_voodoo
    Considering the year and the size of the modest motor I run, perhaps, a MILD tune is what I (my humble 4D56) probably can handle.....anything more complicated and am likely to go put-put in middle of nowhere!!! Please shoot on the MILD one (if possible) or alternatively hook me onto some link.....mucho gracias!!!!
    Turn the wick up little by little. There are an infinite number of settings between sending a rod through the block and getting a nice shove in the back. You know what you're aimng for.
    As an aside, people forget that charge temperature plays a huge role in power production. Cooler air for the same boost pressure will generally make more power. More oxygen , more fuel can be burnt, and more energy can be obtained.
    Saad
    The problem that you had was not boost pressure but peak cylinder pressure. You have to retard timing just a bit when running such a high boost. Unfortunately, without a direct measurement of cylinder pressure, it's a guessing game at best. Keep in mind that new diesels do run these types of pressures and even higher, without failing.
    As an example, here's a plot of cylinder pressure in bars for a 2 litre 4 cylinder common rail engine making 200 N-m torque (BDC to BDC during compression, injection and combustion):
    2KD INJECTORS -978075
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  3. #22
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Next time first thing I'll do is to install an exhaust temperature gauge and cooler. Anyway thanks for the info.
    I have a LCII 95 with 1KZTE ETCS-i version swapped. Any tips on performance tuning on that???
    Drive a Legend. Drive a Land Cruiser
  4. #23
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    All bit too techincal. Will certainly look up you guys again once my surf is ready.
    Pakwatan Explorer
  5. #24
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    wish u best of luck bro. Love ur collection
  6. #25
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    Thank you once again for some wise input.....already have played with that stick to raise the boost a bit.....the turbo has a stock top mounted intercooler.....a free flow exhaust was copied from one of my 5 dr japanese domestic jero( had a ralliart insatalled apparatus when it was imported).....and the motor itself being totally stock!!! It indeed is not the fastest in its class( especially when you are pitched up against the new EFI twin cam 4D56s, 4M40s, J20As, 2KDs) but does the trick, EVERYTIME....all the mods are worth considering when one has a technical hand, like yourself, around.....with the kind of local expertise available, I'd rather put my money on 'going basic' and finish the race!!!
    MEN DO IT AT DAKAR!!!
  7. #26
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Mitsu_man
    can u please post pictures of your ride and specs.
    Thanks
  8. #27
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Saaduk,
    Sami,
    When in Karachi, you guys are more than welcome to have a look and tweek up my Surf (-:
    Regards
    Sajid
    Pakwatan Explorer
  9. #28
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    sajdd, thanks alot. Well I might go to Shuba bazar on sunday, have seen a very nice complete exhaust system (japanese original performance JASMA approved) especially designed and tuned for surf. When it gets into my hands ill take some pics and send it to you if incase you are interested. These guys dont know their original worth and might cost us way cheaper.
  10. #29
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @saaduk
    Sorry for the delay as I was away for the rally! 'Specs' are no rocket science and therefore better left alone....so feast your eyes
    2KD INJECTORS -979496
    2KD INJECTORS -979497
  11. #30
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    take a look at my poooooooooooooooojaaaaaaaaroooooooooooo
    2KD INJECTORS -979529
    2KD INJECTORS -979530
  12. #31
    Sep 2004
    35
    3,701
    8 Post(s)
    MITSU_MAN
    Good going! I have to ask though, isn't the front of your vehicle a bit "exposed"? I'm heading over to the 4x4 section to see the results and pictures of the rally (if there are any, that is).
  13. #32
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    Yup...you are correct....had to do awat with both the bumpers to shed some weight!!!
    @saaduk
    Nice jero....out of mine, I like this one the most.
    2KD INJECTORS -981047
    2KD INJECTORS -981048
  14. #33
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @saaduk
    Haha....just kiddin'....here comes the real one....
    2KD INJECTORS -981056
    2KD INJECTORS -981057
  15. #34
    Sep 2004
    35
    3,701
    8 Post(s)
    ^^^Very nice Mashaallah! It's got a IRS doesn't it? What's it do on the 0-60 sprint? Manual or Auto? *too many questions and this thread is going way, way of course*
  16. #35
    Sep 2004
    35
    3,701
    8 Post(s)
    sajidd
    When I make a trip back to Pakistan - and Karachi to be precise, I'll be sure to look you up! And thanks a lot for the invite.
    Cheers!
    Sami
  17. #36
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    Thanks!!! IRS??? All I know that it has a 3.5 V6 MIVEC motor (280 horses if my stats dont fail me) with independent rear suspension. The tranny is auto with a triptronic mode.
  18. #37
    Sep 2004
    35
    3,701
    8 Post(s)
    Sorry, Independent Rear Suspension - which the 2nd Gen didn't have originally. And have you done any 0-60 times of your own? Or such tomfoolery doesn't interest you?
  19. #38
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sami_voodoo
    Haha....it is 11 years old and has clocked 27K so far..... I intend keeping it the way it is!!! Has been gunned/redlined occasionally but never timed.....more of a collectors thing(only 2100 units made???) than a daily drive.
  20. #39
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    awesome machine u got there Mashallah.. I knew I knew u had the evo. Thumbs up.
  21. #40
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @saaduk
    Thank you for the kind comments. Glad you liked it!!!
