Results 1 to 3 of 3
Thread: WUERTH PRODUCTS
    wuerth's Avatar
    Aug 2009
    33
    Default WUERTH PRODUCTS
    Dear All Members,
    Now WUERTH Products available in Pakistan, It is high time to
    introduce our high definition and innovative products. Its sure that
    these products have magic towards ur car performance.
    Price list is enclosed here:
    table cellpadding=0" cellspacing=0" width=1088"
    colgroup span=1"col span=1" width=36"/colcol span=1" width=73"/colcol span=1" width=89"/colcol span=1" width=177"/colcol span=1" width=0"/colcol span=1" width=72"/colcol span=1" width=76"/colcol span=1" width=68"/colcol span=1" width=72"/col/colgroup
    tbody
    Sr. #
    Art. No.
    Brand Name
    Product
    Features
    Contents
    Pack QTY
    Retail
    Consumer
    Price
    Price
    0893-477
    saBesto
    Plastic Care Compound
    Plastic & rubber parts remain supple, prevents material from becoming brittle and faded, water & dirt repellent, Silicone free, AOX free
    1000 ML
    6 X 1
    sup
    PKR 1,650
    /sup
    sup
    PKR 1,875
    /sup
    8923330
    saBesto
    Rapid Windscreen Cleaner
    Neutral glass cleaning concentrate based on aqueous surfactants 1:100 with aroma for use in summer; pH undiluted=6.0-7.0
    32 ML
    25 X 0.032
    sup
    PKR 150
    /sup
    sup
    PKR 200
    /sup
    8931541
    saBesto
    Rubbing Compound
    The silicone-free formula cleans, smoothes and polihes the point to a high sheen in one operation
    1000 grams
    6 X 1
    sup
    PKR 1,500
    /sup
    sup
    PKR 1,650
    /sup
    8931551
    saBesto
    Finish Polish High Gloss
    The extremely fine particle size guarantees the reliable removal of the very smallest irregularities in paint and micro-fine scratches.
    1000 grams
    6 X 1
    sup
    PKR 1,500
    /sup
    sup
    PKR 1,650
    /sup
    5
    89310
    saBesto
    Carburettor & Throttle Cleaner
    Highly active system cleaner fort he removal of contaminants and deposits in the intake and throtle area without any disassembly, aswell as for calibrated bore-holes and nozzles. Outstanding dissolving power for oil, grease, resin and paint residue
    500ML
    12 X 1
    sup
    PKR 520
    /sup
    sup
    PKR 600
    /sup
    6
    8935562
    saBesto
    Radiator Cleaner
    Alkaline, pH 8-9, Antifreeze-compatible, highly effective surfactant mixture, Loosens and binds oily and greasy residues
    250 ML
    12 X 0.25
    sup
    PKR 680
    /sup
    sup
    PKR 830
    /sup
    7
    8901087
    saBesto
    Brake Cleaner
    Does not contain chlorohydric acid C.F.C, aromatics or substances classified as health damaging
    500 ML
    12 X 0.5
    sup
    PKR 450
    /sup
    sup
    PKR 600
    /sup
    8
    890100
    saBesto
    Contact Spray
    Helps eliminate of ignition problems
    300 ML
    12 X 0.3
    sup
    PKR 550
    /sup
    sup
    PKR 630
    /sup
    9
    8902
    saBesto
    Rost Off
    Resin and acid-free, Silicone-free, compatible with rubber and seals
    300 ML
    12 X 0.3
    sup
    PKR 420
    /sup
    sup
    PKR 500
    /sup
    10
    890030
    saBesto
    Sks Protection (Grey & Black)
    Based on water dispersent Copolymers, can be painted over and solvent free
    1000 ML
    12 X 1
    sup
    PKR 1,200
    /sup
    sup
    PKR 1,350
    /sup
    11
    8935651
    saBesto
    Diesel Additive
    Concentrated agent based on systhetic components as used in national and international diesel fuels, does'nt contain flow property improvers
    300 ML
    12 X 0.3
    sup
    PKR 750
    /sup
    sup
    PKR 900
    /sup
    12
    893559
    saBesto
    Petrol Additive
    Proven effective cleaning by a complete-engine test, Corrosion prevention meets DIN 50017 standards
    300 ML
    12 X 0.3
    sup
    PKR 650
    /sup
    sup
    PKR 800
    /sup
    13
    893557
    saBesto
    Engine Oil Additive
    Conforms to the modern API engine oil standards, Neutralises aggressive combustion acids, Supplements the spent active ingredients of motor oil
    300 ML
    12 X 0.3
    sup
    PKR 680
    /sup
    sup
    PKR 850
    /sup
    14
    893106
    saBesto
    HHS 2000
    A highly polymerised synthetic lubricnts. Lubricates components exposed tohigh pressure, impacts and viberations, free from silicone, resins and acids.
    500ML
    12 X 0.5
    sup
    PKR 580
    /sup
    sup
    PKR 700
    /sup
    15
    890104
    saBesto
    Battery Terminal Protector
    Blue, lomg-lasting, heat-resistant film protects battery poles, pole terminals and plug connection from corrosion, weather and battery acids
    150 ML
    12 X 0.15
    sup
    PKR 450
    /sup
    sup
    PKR 550
    /sup
    16
    10892001017
    saBesto
    Radiator Coolant
    Anti Rust, Anti Corrosion, Anti Scaling
    1000 ML
    12 X 1
    sup
    PKR 180
    /sup
    sup
    PKR 225
    /sup
    Syed Tanzeel Hussain
    Area Development Manager
    0345 469 0870
    /tbody
    /table
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Are the prices per pack i.e. 12x0.3 or per container i.e. 0.3
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    cant see any price list....upload again
    Still Play with Mogs... DeeMog 421.129 1986... http://www.youtube.com/user/DeeMog421
    http://www.pakwheels.com/forums/4x4-clubs-off-roaders-suv/87109-team-unimog-punga-project
