Dear All Members,
Now WUERTH Products available in Pakistan, It is high time to
introduce our high definition and innovative products. Its sure that
these products have magic towards ur car performance.
Price list is enclosed here:
table cellpadding=0" cellspacing=0" width=1088"
colgroup span=1"col span=1" width=36"/colcol span=1" width=73"/colcol span=1" width=89"/colcol span=1" width=177"/colcol span=1" width=0"/colcol span=1" width=72"/colcol span=1" width=76"/colcol span=1" width=68"/colcol span=1" width=72"/col/colgroup
tbody
Sr. #
Art. No.
Brand Name
Product
Features
Contents
Pack QTY
Retail
Consumer
Price
Price
0893-477
saBesto
Plastic Care Compound
Plastic & rubber parts remain supple, prevents material from becoming brittle and faded, water & dirt repellent, Silicone free, AOX free
1000 ML
6 X 1
sup
PKR 1,650
/sup
sup
PKR 1,875
/sup
8923330
saBesto
Rapid Windscreen Cleaner
Neutral glass cleaning concentrate based on aqueous surfactants 1:100 with aroma for use in summer; pH undiluted=6.0-7.0
32 ML
25 X 0.032
sup
PKR 150
/sup
sup
PKR 200
/sup
8931541
saBesto
Rubbing Compound
The silicone-free formula cleans, smoothes and polihes the point to a high sheen in one operation
1000 grams
6 X 1
sup
PKR 1,500
/sup
sup
PKR 1,650
/sup
8931551
saBesto
Finish Polish High Gloss
The extremely fine particle size guarantees the reliable removal of the very smallest irregularities in paint and micro-fine scratches.
1000 grams
6 X 1
sup
PKR 1,500
/sup
sup
PKR 1,650
/sup
5
89310
saBesto
Carburettor & Throttle Cleaner
Highly active system cleaner fort he removal of contaminants and deposits in the intake and throtle area without any disassembly, aswell as for calibrated bore-holes and nozzles. Outstanding dissolving power for oil, grease, resin and paint residue
500ML
12 X 1
sup
PKR 520
/sup
sup
PKR 600
/sup
6
8935562
saBesto
Radiator Cleaner
Alkaline, pH 8-9, Antifreeze-compatible, highly effective surfactant mixture, Loosens and binds oily and greasy residues
250 ML
12 X 0.25
sup
PKR 680
/sup
sup
PKR 830
/sup
7
8901087
saBesto
Brake Cleaner
Does not contain chlorohydric acid C.F.C, aromatics or substances classified as health damaging
500 ML
12 X 0.5
sup
PKR 450
/sup
sup
PKR 600
/sup
8
890100
saBesto
Contact Spray
Helps eliminate of ignition problems
300 ML
12 X 0.3
sup
PKR 550
/sup
sup
PKR 630
/sup
9
8902
saBesto
Rost Off
Resin and acid-free, Silicone-free, compatible with rubber and seals
300 ML
12 X 0.3
sup
PKR 420
/sup
sup
PKR 500
/sup
10
890030
saBesto
Sks Protection (Grey & Black)
Based on water dispersent Copolymers, can be painted over and solvent free
1000 ML
12 X 1
sup
PKR 1,200
/sup
sup
PKR 1,350
/sup
11
8935651
saBesto
Diesel Additive
Concentrated agent based on systhetic components as used in national and international diesel fuels, does'nt contain flow property improvers
300 ML
12 X 0.3
sup
PKR 750
/sup
sup
PKR 900
/sup
12
893559
saBesto
Petrol Additive
Proven effective cleaning by a complete-engine test, Corrosion prevention meets DIN 50017 standards
300 ML
12 X 0.3
sup
PKR 650
/sup
sup
PKR 800
/sup
13
893557
saBesto
Engine Oil Additive
Conforms to the modern API engine oil standards, Neutralises aggressive combustion acids, Supplements the spent active ingredients of motor oil
300 ML
12 X 0.3
sup
PKR 680
/sup
sup
PKR 850
/sup
14
893106
saBesto
HHS 2000
A highly polymerised synthetic lubricnts. Lubricates components exposed tohigh pressure, impacts and viberations, free from silicone, resins and acids.
500ML
12 X 0.5
sup
PKR 580
/sup
sup
PKR 700
/sup
15
890104
saBesto
Battery Terminal Protector
Blue, lomg-lasting, heat-resistant film protects battery poles, pole terminals and plug connection from corrosion, weather and battery acids
150 ML
12 X 0.15
sup
PKR 450
/sup
sup
PKR 550
/sup
16
10892001017
saBesto
Radiator Coolant
Anti Rust, Anti Corrosion, Anti Scaling
1000 ML
12 X 1
sup
PKR 180
/sup
sup
PKR 225
/sup
Syed Tanzeel Hussain
Area Development Manager
0345 469 0870
/tbody
/table
