Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Like Tree1Likes
Thread: Fitting a turbo on 3B engine
    I_M_I_2's Avatar
    Feb 2006
    34
    201
    Default Fitting a turbo on 3B engine
    Guys,
    Have searched the net and concluded that it is possible to install a turbo on a 3B engine.
    I would like to know if that would be any good? What performance improvements will it bring and the side effects too.
    Plus, was hoping if anyone would know where to obtain the turbo kit from, and the estimated cost.
    Thanks in advance for any comments
    Ace
    Ace is offline
    Ace's Avatar
    May 2004
    42
    301
    Brother,
    Its no use puting a Turbo on a 3B. Instead swap it with a 13B-T which is the Turbo version of 3B. (basicaly they instaled a turbo on a 3B and renamed it 13B-T)
    I_M_I_2's Avatar
    Feb 2006
    34
    201
    Thanks for the reply mate. and how much will a swap cost me? for a good condition 13B-T.
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Agreed, go for the 13B-T instead. That's a good engine. I have heard of people successfully placing a turbo on a 3L engine in Pakistan. Sorry, can't help you with prices, but beware, prices are more these days because of the turmoil in the northern areas.
    RKR
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    There are two types of 13BTs available in the market. From effeciency point of view, both r equal. One is the older one which has got sleeves like a std 3B. The other does not have sleeves, resulting in less noise than the simple one. The one with sleeves will cost you around 1,50 to 1,55 and the other one would be within 2 lacs.
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    I understand that its a relatively simple operation to latch on a turbo onto the 2B or 3B engines and should cost around 6-10K depending on which turbo. Have never seen one but know that it is doable..
    Upside: There should be a significant improvement in performance and possibly fuel efficiency as well. The AXT turbo website gives you dyno charts claiming that their 3B turbo would outperform a 13B-T http://www.axtturbo.com.au/toy3B.html
    Downside: I am told that the life of the engine would be compromised as the standard pistons are not really configured to take the additional load. Also understand once installed, it is difficult to take the turbo off and will cost you more. Also I would think that that you would have to be very careful with temperature issues as you may overheat your engine if things are not working 100%.
    Alt Views: There are a gazillion stories of people slapping on turbos on petrol and diesel engines which seem to run well... though this is not so popular in Pakistan....Note: AXT which is a credible Australian company sell a host of custom TurboKits for standard diesel engines of all makes. These kits sell north of US$2,000 and are quite popular it seems. See website: http://www.axtturbo.com.au/Turbos.html.
    My Bottomline: I would not replace 3B with a 13BT but rather go all out for a 1HZ or 1HD... If i was in the mood for a panga project I would take the risk of installing the turbo as long as I could afford replacing/upgrading the engine if things go wrong....if my pocket was not deep enough and i was the age that I am now, I would sit back and enjoy the 2B/3B....its a great engine for what it is!!
    Hope that helps...but if you still have an itch do speak to Master Mechanic Farooq Awan who has some experience in this territory. His number is 0333-5207251.
    "If YOU don't believe in what you're doing it'll never work."
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    ^^^^^ Great advice. I would go got the HZ or th HD engines also. But I hear they are crazy expensive these days. True?
    RKR
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    I would suggest 1 UZ like that trooper has in Lahore.
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
    Ace
    Ace is offline
    Ace's Avatar
    May 2004
    42
    301
    1HD-FT (Black top)=6 Lacs
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by jeepaholic
    Oh man! that lexus engine would be mean! But.... can you find it in Pakistan? Also, I like you already, for recommending a petrol engine, but not sure how much the offroaders will appreciate it! I get it all the time from them for having a 3F.
    RKR
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by Ace
    Bloody hell! What about a 1HZ, perfect offroad engine I feel. There are people who put on turbos on those all the time.
    RKR.
  12. #12
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    RKR
    [/quote]
    Kuch to log kahain ***,
    logon ka kam hai kehna,
    choro baikar kee baton ko,
    kaheen beet na jayay rainaa,
    lets go V8
  13. #13
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    ^^^^^^ Wah, wah, wah, wah. Irshaad.
    RKR
  14. #14
    I_M_I_2's Avatar
    Feb 2006
    34
    201
    Lol @ Shahid bhai, sir aap toh sha sey shaayiree karnay lagay. Mahl-o-vuqu ki munaasibat se khoob farmaya.
    @ Suhaib Kiani, Gratitude for the detailed response mate, much appreciated . Considering the prices of better engines, and the fact that my 3B has never let me down so far in the 9 years of my ownership of this vehicle, i guess i will stick to it afterall. Plannning to give it a overhaul in the near future insha Allah.
  15. #15
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Me and Farooq got into doing just this for my Cherokee a few years back. We sourced a spare manifold and retrofitted a Garrett Turbo onto it. It was just a tuck welded experiment. I have a few pictures somewhere but I will have to look for them. We could not get to finishing the project and installing it into the engine. So it is doable? Yes it is. But doing it good is a question mark. There are a lot of issues involved here and not just welding a turbo onto a manifold. I am sure Farooq would come onto this thread soon to ellaborate.
    Also.. There is a rare turbo fitted 3B model as well. Either that or the one I know installed into a BJ40 was aftermarket (if it was, it was done clean). The vehicle is owned by Mohsin who is an IJC member and frequents this forum off and on. I hear it is a significant improvement over the regular 3B. The installation was, again done by Farooq.
    Thanks
    Ehsan
  16. #16
    nuic's Avatar
    Jun 2008
    31
    169
    i have recently bought a bj60 with a 3b i wanted to get the engine swapped with the 1hz or 1hd .. as RKR said the prices are rediculass.they r rangine from 250 to 350 just the engines . and thn decided to go for a turbo on the 3b. so u will somebody with u on this. i am also gettting a new gearbox the 13b one 5 forward.i am hopping it will turn out fine. if i blow it then i guess ill be spreading my hands for a new engine. haha. but it will go well its not a big issue just need to no the roght ppl and there r plenty of right ppl here on pkw
  17. #17
    I_M_I_2's Avatar
    Feb 2006
    34
    201
    @Ehsan, thanks mate, your post was encouraging. lets hope Farooq drops in some time soon .
    @nuic, mate am so glad to see you on a similar project. do keep me posted on your progress, or we can go around together if you want to. Your's will be the rat though, i cant afford a new engine at the mo . Regrding the 5 speed on a 3B, will that do any good?
  18. #18
    nuic's Avatar
    Jun 2008
    31
    169
    I_ M_I_2
    isntalled the 5 speed gear box. its worked wonders on high speeds
    tomoro ill go inshallah to find a turbo .. will keep u up dates
  19. #19
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Hi friends, i need a BJ60 on very urgent basis please find me one. Regards. plz sms on 03005271101
  20. #20
    salman_m5's Avatar
    Nov 2004
    Melbourne
    31
    2,383
    @jeepaholic
    sent u a msg
    1uzfe is also available
