Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 170
Like Tree6Likes
Thread: MUTT SUV Project - Stage 1 Complete
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Cool 6.5 Inches High Travel Lift
    Stage 3: Frame modifications
    MUTT SUV Project   Stage 1 Complete -1340591
    Stage 2 suspension complete: IFS + IRS e-Diff Locks, 1.5' Lift, 35" Tires
    Stage 1: 5 speed hi-low 4x4 Drive Train, 2.3 TD with Intercooler Engine
    MUTT SUV Project  - Stage 1 Complete -388744
    AM General Jeep M825 MUTT | 3 C Turbo Diesel
  2. #141
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Default Friday Night Turbo Gauge Install
    Today I installed a Turbo Boost Gauge for my jeep. I got it from Zamzama Karachi.
    Finally now I am able to monitor the boost level on my Jeep. I am getting around 0.85 bar or 12 PSI of boost from the turbo, which is pretty decent. The gauge also shows manifold vacuum. I have also linked up the boost / vacuum line with fuel boost compensator.
    I took it for a test run and at 3000 RPM 4th Gear I was touching 100 kph with 12 PSI boost. I ran out of road and gutts to go in the 5th Gear Came across cops on the road, they were so confused looking at my jeep and were wondering what I am doing at 3 AM in the morning, lolz
    I am getting boost lag from the wastegate, causing spool lag and boost starting from 2100 RPM. I may have to install a check value in the boost controller / wastegate actuator line to fix boost lag; this should hopefully bring it down to 1600 to 1800 RPM.
    MUTT SUV Project  - Stage 1 Complete -118847
  3. #142
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Need some help.
    I have been researching on good body fabricators in Lahore with no luck. Most of the denter / painters I have come accross do stuff manually with crude hammers, but the kind of stuff I need requires fabrication with machines & presses.
    Please recommend someone good in Lahore for this Job.
    • Rust removal: sand blasting, sheet metal, and galvanization.
    • Jeep doors,
    • roll bar,
    • tail gate,
    • and bumpers.
    Also please recommend some fiberglass / plastic fabricator for:
    • Fenders
    • Roof Top
    • Interior Trims / Parts
  4. #143
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
  5. #144
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
  6. #145
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    very nice video indeed one of its kind on this whole web site wit extream off roading
    one only can imagine
  7. #146
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Quote Originally Posted by cyrius View Post
    thanks for the praises.
  8. #147
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    to day was a very busy day
    i hav done some mods to my stock m151 it was purely based on web research
    i have modified the orignal air cleaner with a nissan air filter adjust the carb settings with the help of vicky oil and filter change new tem gauge installed
    the performance has increased to 20% jeep seems to be very light and much more power full than before less niose and 5%less fuel cosmuption
    the filter and carb mod really helped
  9. #148
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Quote Originally Posted by aisheikh View Post
    MUTT SUV Project  - Stage 1 Complete - 87466
    Assalamwalikum, can you tell me a bit more about this dash meter? From which vechile was it taken off? where did you purchase it from? How much? Regards
    Sajid
    Pakwatan Explorer
  10. #149
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Quote Originally Posted by sajidd View Post
    Sajid
    Its out of some 4wd Toyota (dont know the model), bought it from bilal ganj for 3000, spent 1500 for modification / conversion of guages from 24v to 12v.
  11. #150
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Default m715 Jeep Truck
  12. #151
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    started jeep today
    but carb is not performing well
    i think i will also need carb from you
    i try is it works or not any ways talking to sarmad he was telling me suzuki pickup or changan chinies very near to the original ones
  13. #152
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    started jeep today
    I guess all the available spares are coming in handy for you.
  14. #153
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Default Its Getting There
    Slowly but surely the mods are coming out right.
    Enjoy the pics.
  15. #154
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    MUTT SUV Project  - Stage 1 Complete - 163309 MUTT SUV Project    Stage 1 Complete Nov 15 Siphon 18 MUTT SUV Project  - Stage 1 Complete - 163310 MUTT SUV Project    Stage 1 Complete Nov 15 Siphon 19 MUTT SUV Project  - Stage 1 Complete - 163311 MUTT SUV Project    Stage 1 Complete Nov 15 Siphon 20 MUTT SUV Project  - Stage 1 Complete - 163312 MUTT SUV Project    Stage 1 Complete Nov 15 Siphon 8 MUTT SUV Project  - Stage 1 Complete - 163313 MUTT SUV Project    Stage 1 Complete Nov 15 Siphon 11
  16. #155
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    Default dying
    arslan no progress on the thread though u hav made progress with the mutoyota
    the thread is dying put some news upon it and make it rolling and live again
  17. 05-01-2011, 09:41 PM
    Site Banned
  18. #156
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    LPG / Propane Injection Installed.
    EGT Probe and Sensor Installed.
    Vehicle Tested for 15' Jump.
  19. #157
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    @cyris
    if you note the pictures never show up and stickies dont' allow the post to come up. Hence, not too motivated in updating the thread.
    However, the project is on track and the monster is in the making :-)
  20. #158
    baburawan's Avatar
    Dec 2010
    46
    824
    2 Post(s)
    Default Comment please
    Quote Originally Posted by sarmadqureshi View Post
    What's going to be left of the MUTT ? Wouldn't it be better to put the MUTT shell on a CJ5 & drive around.
    Sarmed, I really don't understand, why ppl want to make a Prado, or a Pajero out of MUTT???????
  21. #159
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Quote Originally Posted by baburawan View Post
    @Cyris
    this is what I mean. No positive contribution, as ppl have no idea about mods and performance tuning.
    @baburawan
    appreciate your indirect candid feedback. I am sure you are familiar with the stock Mutt performance. If you need a totaly different experience let me know.
    @All
    If you like "green" jeeps with "skinny" tires then please don't comment here. Mind you there are very few purists out there ( I have respect for them). If a Mutt has a suzuki or vw carb, changed engine, desi replacement parts e.t.c. its not pure.
  22. #160
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    arslan thats why i asked u put some pics with the performance and the torque ur getting with the mods plus horsepower ur mutt have then ppl will know what ur talking about
    plus 1 more thing let every one hav a right what they like to express (democracy)
Tags for this Thread
