Results 1 to 4 of 4
Thread: Can CJ 7 be converted to Wrangler
    atherkamal's Avatar
    Jan 2009
    Kharian
    51
    27
    Default Can CJ 7 be converted to Wrangler
    Please can anyone guide me that complete Wrangler can be fitted on any old chasis of which jeep ?
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Athar Sb,
    Yes, a Wrangle body can be housed on an old CJ7 chassis.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Looks like you have found a NCP wrangler. Please share the pics.
    Believe half of what you see and none of what you hear.......
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Yes. It can be fitted onto a CJ7 chasis but there will be a few mods that will have to be done.. Apart from the others:
    - If there is and discrepancy in wheelbase of the two vehicles, the CJ chasis will have to be elongated that much
    - The wrangler diffs are wider than the CJ and the body is wider accordingly. Maybe if you take off the flares, the width will be fine or put in spacers (undesirable) or wider tires. Otherwise, the CJ diffs may leave the tires short of the flares.
    - The mount points will have to be modified to keep the body at a parallel level to the ground. Get a good experienced Frame welder to get this done.
    Just what I can think of.. I may be wrong..
    Ehsan
