Sherwan88 your tone is very impolite. it appears u have been offended by my idea, but mind it you have offended me!
Arguments are based on logic not harsh remarks, these show manners. And manners are for one reason people around you accept you without getting irritated.
Let me tell you correct approach.
Take a stance without any bias.
If it can't be done then support it by reason and logic.
If it can be done then support it by reason and logic.
But it can only be proved once its actually done.
1-"you cannot mount a shaft and a differential to the output yoke to front wheel drive gearbox. " ]] yoke can be changed and U joint assembly can be mounted.
2- "You won't be able to have the ratios work, because the the gearbox has a built in diff, and adding anouther diff will just reduce it a lot further. " ]] Ratios can be further analyzed if required gears can be fabricated locally in karachi.
3-"Second of all they are not built for this kinda stupid stuff, so they won't last a while, third, they won't even work, because when the transfer case will lock the shafts the shafts wont lock the fron't and rear diffs, lots of other stuff.
]] there is no trnasfer case involved here. More over the argument that some thing can be only used for which its made is stops all inovation and is not always correct, think about it why wont it work and last what will be the torques angular velociites etc involved.. only some thing substatial can be said.
Lastly solving a few text book numerical and working as shift manager in some plant does not make a person engineer. Engineer is some thing more than that.
