Results 1 to 10 of 10
Thread: Pls help me identify this engine..
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Default Pls help me identify this engine..
    Saw this in a Bj60 that had auotmatic transmission.
    What engine is this?
    Is it reliable? durable?
    What is the consumption with auto transmission?
    Is consumption any better with manual transmission?
    What known weaknesses of this engine?
    Pls help.
    Salaams
    Sajid
    Pls help me identify this engine -612177
    Pls help me identify this engine -612178
    Pakwatan Explorer
    supraman2jz's Avatar
    Jun 2008
    33
    2,697
    76 Post(s)
    It's a Toyota 1HD-T turbo diesel engine making around 160bhp. It's a 4.2L 6cyl engine so you can assume how much mileage it'll get you! Can you even get these here in Pakistan???
    "Being between arabs, you call it "Jimmss Yukaan Sagheer", or GMC yukon." - Xulfiqar.
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Thanks.
    Is it a solid reliable engine ? Or a lemon?
    Also does not seem to generate much HP given its size. What do you think ?
    Quote Originally Posted by supraman2jz
    Â*
    Pakwatan Explorer
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    1HD is the top of the line Toyota diesel that is available, intallable and manageable in Pakistan. Cost was around PKR 250k from what I have been told but I have seen higher figures from users on this forum. A friend has it in a 70 series Toyota Bundero (whacko stuff indeed!!!) and its been running very well. Great thing is that its quite a straight forward bolt in to a variety of Toyota transmisssions including hilux surf and most 60-100 series LCs. From the photo however, my impression was that the engine you saw was actually a 1HZ but in any case here are the comparative specs from my worksheet:
    table cellpadding=0" cellspacing=0" width=544"
    colgroup span=1"col span=1" width=64"/colcol span=1" width=42"/colcol span=1" width=30"/colcol span=1" width=153"/colcol span=1" width=255"/col/colgroup
    tbody
    Engine
    Disp.
    Fuel
    Power
    Torque
    2L-TE
    2.4l
    D
    97HP (72.3kW) at 3800 RPM
    177 ft·lb (240 N·m) of torque at 2400 RPM
    1-KZ TE
    3.0l
    D
    130 hp (97 kW) @ 3600 rpm
    29.3 kgf·m (287 N·m) @ 2000 rpm
    13B-T
    3.4l
    D
    120 hp (89 kW) at 3400 rpm
    207 ft·lbf (284 N·m) of torque at 2200 rpm
    12H-T
    4.0L
    D
    135 hp (101 kW) at 3500 rpm
    231 ft·lbf (312 N·m of torque at 2000 rpm
    1HZ
    4.2L
    D
    133 hp (99 kW) at 4000 rpm
    207 ft·lbf (280 N·m) of torque at 2200 rpm
    1HD-FTE
    4.2L
    D
    164 hp (122 kW) at 3400 rpm
    280 ft·lbf (380 N·m) of torque at 1400 rpm
    1KD-FTV
    3.0L
    D
    170 hp (125 kW) at 3400 rpm
    260 lbf·ft (352 N·m) of torque at 1800-3400 r
    Source : Wikipedia and http://www.geocities.com/motorcity/pit/9975/dataBySubject/DieselEngines.html
    /tbody
    /table
    "If YOU don't believe in what you're doing it'll never work."
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Quote Originally Posted by SuhaibKiani
    tbody
    Engine
    Disp.
    Fuel
    Power
    Torque
    2L-TE
    2.4l
    D
    1-KZ TE
    3.0l
    D
    13B-T
    3.4l
    D
    12H-T
    4.0L
    D
    1HZ
    4.2L
    D
    1HD-FTE
    4.2L
    D
    1KD-FTV
    3.0L
    D
    /tbody
    /table
    Kiani sahib, thanks for the copmarison. This 1KD engine, seems amazing.. 3000 cc and so much hp + torque.. sure beats the crap out of the bigger older engine.. in terms of sheer perofrmance, not sure about endurance.
    So now the question remains it is 1hdt or 1hzt?
    Pakwatan Explorer
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    The engine is actually the good old 12HT ...supposedly one of the best and most reliable diesel engines Toyota ever made, only drawback is that local availability and parts are a bit on the scarce side but I think are still manageable.
    The KDs are very impressive indeed and as someone mentioned earlier, quite the choice esp for rally purposes. Unfortunately, it may be a few years before we can crack the CRD code and find some jugar for the diesel-sulphur issues. Having said that looking at the specs and current diesel costs this may happen sooner than expected.
    Pls see 1KD performance discussion link below (surprisingly cannot find much on related discussion on the net) . Apparently its quite a modification friendly unit with impressive results in Thailand: the new home of all if not most Hiluxs - Jalla watan kar dee gayee hai Hilux Japan se....kutch Musharraf jaisa salook kiya gaya lagta hai http://www.toymods.net/forums/showthread.php?t=11898
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    How is 12HT in terms of consumption?
    And yes I have seen the 1kd in action, and right now it rules its category as evident by rally results where vigos have constantly taken the podium.
    Pakwatan Explorer
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    The 12T is a fantastic engine. It will also give you great consumption figures, 7-9km/l depending on the heaviness of your foot. The 1HD-T is an envious engine too, but won't give you those consumption numbers. HP is nothing unless you specify what you want to use your vehicle for. For rallying, the 1KD will be a better match, for offroading, the 1HD cannot be beaten. All hell breaks loose at 1400 RPM, that is insane!!!!!
    RKR
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Quote Originally Posted by raohamid
    The 12T is a fantastic engine. It will also give you great consumption figures, 7-9km/l depending on the heaviness of your foot. The 1HD-T is an envious engine too, but won't give you those consumption numbers. HP is nothing unless you specify what you want to use your vehicle for. For rallying, the 1KD will be a better match, for offroading, the 1HD cannot be beaten. All hell breaks loose at 1400 RPM, that is insane!!!!! RKR
    Thanks for the info, sounds like 12ht is a keeper of an engine as far as off roading is concerned.
    Pakwatan Explorer
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    sajid- if you have the option of going for it, just go for it, i assure you it will not dissappoint.
    I am seriously contemplating the 12ht in my RKR for the fuel figures.
    RKR
