Results 1 to 10 of 10
Thread: Prado 3.0d T-BELT light is on...what to do?
    Lafafa's Avatar
    Jun 2005
    33
    3,102
    10 Post(s)
    Default Prado 3.0d T-BELT light is on...what to do?
    hello guys. the T-BELT light just switched on today when i was entering my home and now it is on. Its a 3-door prado 1998 model 3.0d auto tranny.
    i believe this is the timing belt light....is that correct??? why did it turn on...i guess the belt needs changing??
    and how do i reset the light?
    The SUB will do what the BOX tells it to do!
    malik1983's Avatar
    Jan 2009
    others
    33
    334
    Change ur timing belt
    and the light will off automatically
    syedmughees's Avatar
    Sep 2006
    31
    369
    4 Post(s)
    change t belt
    Love your Machine it reflects your personality
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    Changing timing belt. After that disconnect battery terminals to reset the code. Or refer to user's manual, as there must be some other way to reset
    Suggestions required
    chinyoti's Avatar
    Sep 2005
    27
    11,964
    5
    108 Post(s)
    5 Thread(s)
    try this
    http://www.hiluxsurf.eu/faq_interior.htm#timing_belt
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    Lafafa's Avatar
    Jun 2005
    33
    3,102
    10 Post(s)
    thank u everyone
    i was a little worried because i dont know anything about the prado.....will change this as soon as possible.
    daniyaljawed's Avatar
    May 2006
    29
    207
    The only good is knowledge and the only evil is ignorance.
    Nov 2008
    35
    10,044
    10 Post(s)
    Quote Originally Posted by Lafafa
    thank u everyone i was a little worried because i dont know anything about the prado.....will change this as soon as possible.
    Not as soon as possible. change it the next time u take out your car or it may end up damaging the valves
    Lafafa's Avatar
    Jun 2005
    33
    3,102
    10 Post(s)
    hehee....just did exactly that!
    the light had turned on at exactly 100,000km. and i changed it the next time i took it out just as panicslayer advised. had to change the timing bearing as well.
    the T-belt light had to be reset manually so had to take out the speedometer and reset it from the rear. opened the dash holding the meter.
    all is good now!
    Porsche_Maker's Avatar
    Oct 2006
    6,388
    Change with Toyota original timing belt and enjoy for next 100k kms.
    Life is a chain of moment of enjoyment and Obedience to Allah, not only about survival
