Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Suggest Plz Jeep SJ410 Making Comfortable How?
    ihsan's Avatar
    May 2005
    Hyderabad
    32
    376
    5 Post(s)
    Default Suggest Plz Jeep SJ410 Making Comfortable How?
    Suggest Plz Jeep SJ410 Making Comfortable How? -614844
    Suggest Plz Jeep SJ410 Making Comfortable How? -614845
    As many of you have seen my Jeep Suzuki SJ410 with Diesel Engine.
    I want to make it more Comfortable, can anyone Suggest me How To Do That?
    Will Lowering it Help?
    Any thing else?
    Jugail
  2. #21
    autoSlaVe's Avatar
    Jan 2006
    33
    286
    @KhakiMB Sir,
    Do u think, Mini and 410 could be compared when it comes to offroading?
    @ the scale of 10, what marks would you give to Mini and 410?
    Peace TV : The Solution for Humanity
  3. #22
    KhakiMB's Avatar
    Dec 2006
    42
    274
    Thumbs up Comparison
    Quote Originally Posted by autoSlaVe View Post
    @KhakiMB Sir,
    For Offroad:
    I would give the 410 a 9 out of 10. And a Mini would get 6 out of 10.
    For Comfort:
    For comfort which the author wants i would give the Mini a 7 out of 10 and the 410 about a 4.
    As mentioned in my earlier post the 410 is not comfortable but King offroad.
    KMB
  4. #23
    bhaiyuji's Avatar
    Aug 2006
    61
    50
    Good advice from KMB. One additional note: The original shocks on SJ410s will probably be worn out, do repair/replace them with original or heavier shocks with or without coils BEFORE you remove too many leaf springs. You will probably save the small additional cost/hassle of replacing broken leafs if you install the coils before removing more kamanis.
  5. #24
    choctalpur's Avatar
    Feb 2010
    Hyderabad
    142
    Changing leafsprings to coil may make it comfortable, but it will reduce its off roading capabilities significantly with more chances of a roll over on sharp turns and emergency brakes. The problem in discussion has no solid solution. The vehicle as someone else put it is meant for offroading, let it be as it is ...
  6. #25
    bhaiyuji's Avatar
    Aug 2006
    61
    50
    On second thoughts I have to agree with choctalpur, leave it alone, well meaning changes without the right know how can make matters worse.
    On a separate note, I believe that proper (appropriate) coils will not only improve the ride (metal AND offroad) but improve articulation and increase offroading safety with an edge over leafsprings but the expense is not worth the minor difference especially with the risk of not getting the right tension springs.
    I would be interested in the firsthand experience of anyone who has used coilovers in a SJ410/SJ413? I know there are many out there as I saw several at the Sind Desert Rally. These guys I assume used the coils for performance rather than for comfort.
