yep pending tasks are: floor rubber/ vinyl covering, rim/tires, door rubber channels, and roll bar. Furthermore, tomorrow FJ40 goes back to workshop for three days for power steering and brake booster fitting.
As for the engine is concerned Raza and my F engine were both done by (AmanaUllah). As per him and his team my engine is silky smooth and running smoother than Raza's engine at this time as Raza's F2 engine is a bit noisier as the rings, pistons, and big end bearing are still tight in the cylinder. After running in they will queit down. I replaced old .75 rings and big ends with the same size new ones, and getting good compression without need of prolonged running in. Carb was given to me by Raza and then I installed a new distributor after which it is running great.
