Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
Thread: Query about spark plugs for Suzuki Jimny(M13a)
    devilz_apprentice's Avatar
    Apr 2006
    26
    2,840
    23 Post(s)
    Default Query about spark plugs for Suzuki Jimny(M13a)
    Salam PWers! I need some info regarding spark plugs for Suzuki Jimny. I'd appreciate it if someone could provide me with all the details(brand, part number, price, etc.) of the spark plugs which will be most suitable for M13a.
    Regards,
    Faizan
    Bumper Sticker: "I feed off other people's rage, so drive carefully :-)."
  2. #21
    bhaiyuji's Avatar
    Aug 2006
    61
    50
    Default Spark plug gap
    If you are going to drive on CNG please reduce the gap from 1.1 mm to 0.9 or from 0.43 to 0.39, also change the plugs twice as frequently as you would on petrol. You might consider using a colder spark plug such as BKR7E-11 but again manually shorten the gaps. factory set is 1.1.
    If you can locate and afford iridium NGK IFR6J11 do not mess with the factory set gap, it will break.
    DENSO K20PR-U11 is a recommended standard plug but "do numbar" are common.
