Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: The DHB Panga : Poor Man's LSD
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default The DHB Panga : Poor Man's LSD
    Jeep Baltoro finally returned from Dr Awan's clinic....
    The DHB Panga  Poor Mans LSD -26220
    .....after receiving a Dual Hand Brake (DHB) surgical implant.
    The DHB Panga  Poor Mans LSD -26222
    The DHB Panga : Poor Man's LSD - 26221
  2. #21
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Quote Originally Posted by sarmadqureshi View Post
    Good for use in farm tractors and have known to be equally, even better used in extreme competition 4x4s.
    http://www.4wheeloffroad.com/techarticles/wheels/131_0707_cutting_brakes/index.html
    Almost all farm Tractors come with factory fitted manual Diff locks.
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
  3. #22
    OmerArshad's Avatar
    Jul 2003
    2,836
    9 Post(s)
    Pakistan got Talent!
    If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man ~ Mark Twain
  4. #23
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    It actually works
  5. #24
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    How did it go over the weekend meet Suhaib bhai? enlighten us with the performance....
  6. #25
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @suhaib
    Very ingenius. Pretty impressive craftmanship!!!
    MEN DO IT AT DAKAR!!!
  7. #26
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Quote Originally Posted by desertdevil View Post
    Asad bhai. Tried and tested the brakes and I must say that these are impressive. Lovely infact. Where one tire would be starving for traction with the vehicle stuck, I would just pull one brake and wala the vehicle would move.. I am getting these in my Cherokee.. Farooq obviously deserves a good deal of the credit for doing all the mechanical work in this. Hats off sir. The idea was equally brilliant indeed..
    Ehsan
  8. #27
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Actually, for this event the setting on the Jeep was quite inappropriate:
    1. Unable to get the 31' inch A/T tyres onto the steel rim set in time and was running the DD smaller H/T tyres
    2. Rear shocks had been mistakenly replaced with shorter set from our collection and on suspension flex, the rear tyres were prone to lifting off
    But the good thing was that with the inappropriate set-up and we got some nice opportunities to test the theory.
    1. Ehsan tried it on the dirt obstacle where on the incline left rear wheel was spinning, he locked on the left HB and left wheel jammed and power was effectively transferred to the right. Nevertheless, no magic result here as firstly H/T tyres and suspension were not supportive and secondly I feel that for extreme obstacles the utility would probably be limited anyway. I think we may have some of this on video.
    2. Ehsan then tried it the climb on the steep climb on the way back, where he claims that the car got stuck and he was able to get it moving up again by using the appropriate HB.
    3. I actually had to use it right at the junction of the main Simly Dam road and the start/finish of the track where I took a rather extreme angle on the left climbing turn onto the road. Front tyres were on the road tarmac and rear left was either off the ground or just spinning in the dirt. Engaged left HB and gave it a good go to make it onto the road.
    So net net, it obviously is nothing close to a diff lock but does give you an additional degree of freedom to climb out of ruts which may pose a stiffer problem otherwise.
  9. #28
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    @Sherwan: I did get a whiff of leather burn smell (likely from the brake drums) on number 3 above, but then again I think most of us have gotten quite at home with that aroma
  10. #29
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by MITSU_MAN View Post
    @suhaib
    Thank you sir. Craftmanship was all Farooq Awan (mechanic) and Jamil Awan (body work). Still need to add some fininshing touches like move the left one slightly inwards and put some paint on there, but the workmanship is solid indeed.
  11. #30
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Thumbs up Poor Man's Winch
    Great Job Sk!!
    What plan for Using hub capstan winches
    The DHB Panga  Poor Mans LSD -27688
    The DHB Panga  Poor Mans LSD -27691
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
  12. #31
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    nice thinnking who ever could come up with this i bet paksuzuki will copy ur idea till 2200
    on a serious note im impressed
    Hanjiii Kaa Storeey Eehh !
