Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Mystery Radiator Coolant – Pajero 2.8
    Founder Follow
    HanifBhatti's Avatar
    Jul 2003
    60
    45,308
    54
    981 Post(s)
    71 Thread(s)
    Default Mystery Radiator Coolant – Pajero 2.8
    On my trip to Naran, just half way up while going to Saif-ul-Maluk my Pajero heated up. We stopped near the Glacier and filled the Radiator with Glacier water.
    After filling it with Glacier water the temperature needle never went above 45%, few days back I filled it with Tap water and the Temp needle is back at 50%
    Can anyone solve this mystery?
    Heating problem was due to radiator blocked with insects and a broken fan shroud
    Formerly known as Libra. Founder Pakwheels.com
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    4 Thread(s)
    Glacier water had less impurities.
    ngen's Avatar
    Oct 2008
    38
    166
    interesting
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    You should have brought a jerry can filled with that water so you could use it again and experiment.
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    You need to find out what kind of temp gauge you have in Pajero if its a 3 step temp reader then your reading does not matter but if its actual reading as some vehicles are then you have different story.
    secondly you need to check the boiling temp of the glacier water and normal Karachi Tap water, you will find your answer.
    Founder Follow
    Jul 2003
    60
    45,308
    54
    981 Post(s)
    71 Thread(s)
    Quote Originally Posted by Storm View Post
    I also think the same
    Quote Originally Posted by Racerf1 View Post
    At that time i didnt know
    In Naran i saw it on 45% but then i thought it must be the cold weather but when i came in warmer areas it was still on 45%
    I dont know what type of Temp meter it has but one thing i know is the i bought it the gauge has been on 50%
    Now from where can i get the glacier water to check the boiling point, lets go again to test it
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    sure, when?
    Founder Follow
    Jul 2003
    60
    45,308
    54
    981 Post(s)
    71 Thread(s)
    sure, when?
    May or June, i will let you know atleast 15 days in advance
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    Roger!
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    @racer
    can you elaborte a little on 3 step temp reader
    its all about power to weight ratio...
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    Quote Originally Posted by Ghuncha View Post
    @racer
    Sure! They have 3 steps of reading points cold/normal operating temp/Hot.
    When you start the car it would show cold and once started and warms up the needle would move to either quarter or half however the setup is.
    Lets say the hot temp is read at 90degrees the needle would start to move directly to hot
    30 is cold
    60 is warm
    90 is hot
    thats how it would read.
  12. #12
    muddman's Avatar
    Jan 2005
    Bahawalpur
    46
    21
    Coolant temprature should not vary much unless you are stalled or moving at very little speed. If you have your fan working properly, it should maintain safe operating temprature for engine. On most gauages, midway point is normal.
    Please head some warning. If you engine is too hot, but your fan is working, you should let the car idle before turning off engine( couple of minutes). this allows for coolant to keep in circulation for a while and helps cool down engine before engine is stopped. Also should not add cold water right away, as it will change metal temprature upon contact. Do not put cold water on the engine. Metals exapand and shrink due ot temprature, may loosen some seals or contact points. Once car is coll down( 15-20 minutes, carfully open coolant reservoir and add additional fluids to reservoir. Opening radiator cap( if your car has one) may release steam and cause burns.
    Finally if you need additional fluids, then have your coolant system check for coolant water mix or leaks. Coolant chemicals help increase boiling point of the water to a higher temperature. This helps keep coolant water mix in fluid form and avoid steaming or increased pressure in coolant system. Mot cars heat up due to less than optimal mix of coolant-water in your vehicle or leakage, or fan issues. Never add tap/stream water to engine. I recommend adding distilled water and coolant mix according to manufacturer's recommendations. Tap or stream water has salts, that will sit in your coolant system, usually causes long term issues, most common is thermostat or temperature sensor failures. Also if you have not used life time coolant, then make sure you change your coolant regularly based on coolant life. Old coolant changes PH, and causes engine corrosion.
    I hope this helps.
  13. #13
    Founder Follow
    Jul 2003
    60
    45,308
    54
    981 Post(s)
    71 Thread(s)
    Quote Originally Posted by muddman View Post
    I hope this helps.
    Excellent Info, Can you please read my question again
  14. #14
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    @racer
    its not 3 step its a normal linear one.
  15. #15
    muddman's Avatar
    Jan 2005
    Bahawalpur
    46
    21
    Quote Originally Posted by Libra View Post
    I read it... only reason I put a long story here, I see lot of people adding water to radiator....simple H2O will become steam and go out of reservoir... info is valid, still... one should not need coolant... I have mine for 100K miles and then replaced it with G2 ( audi life time coolant) just as I was in the shop for timing and thermo replacement. I hope you enjoyed your trip despite temprature guage worries.
  16. #16
    muddman's Avatar
    Jan 2005
    Bahawalpur
    46
    21
    BTW... temp sensors for each car usually have two ranges...check number of electric leads going in..3-4 leads means two dual range sensor. only 2 wires means single range sensor. Some time salts or age of the sensor cause faulty reading in one or both ranges..don't try to scratch off salts/corrosion, wouldn't give you the right reading...temp sensor works on the basis of letting certain amount of current pass thru under certain temprature... computer/guage will read the return current/voltage and asses the temprature. a blanket of salt on sensor changes the environment. I better get to back to my work... LOL...
  17. #17
    Founder Follow
    Jul 2003
    60
    45,308
    54
    981 Post(s)
    71 Thread(s)
    @muddman
    Thanks for the info.
    @All
    Once again, What is the diffrence between Tap water and Glacier water?
    Why the 5% difference in Temp?
  18. #18
    muddman's Avatar
    Jan 2005
    Bahawalpur
    46
    21
    Libra, few theories, that is theories.. Salt contents differ from fresh glacier water and filtered water, ambient temperature differs, as well as atmospheric pressure between your observations.
    If you checked water level and temp after you have moved to different altitude, it may have shown different temperature.
    Since you added water at two different occasions, you must have lost some water due to steam escaping from the system, leaving salts behind either in the fluid or deposited on the temp sensor, you reading may be bit off.
    Ambient temperature difference is also a variable..I think your curiosity ask for breakage of fan shroud, and a trip to Naran LOL... may be this summer
  19. #19
    Porsche_Maker's Avatar
    Oct 2006
    6,388
    @libra
    Thinking of packing and selling Glacier water in place of Coolant and make money
    Life is a chain of moment of enjoyment and Obedience to Allah, not only about survival
  20. #20
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Its easy get some distilled water (from rain, A/C drain etc). Will be as good as glacier water. Wont damage your radiator as well (from rust).
