Results 1 to 15 of 15
Thread: Bodylifting the Hilux Vigo
    qwertypoiu's Avatar
    Feb 2007
    29,129
    153 Post(s)
    3 Thread(s)
    Default Bodylifting the Hilux Vigo
    As we all know, a bodylift is when we lift the body of the Hilux up and away from the chassis of the Hilux. On older model this hasnt been a problem due to the fact that most older Hilux's haven't had airbags fitted, but the current vehicle has and unfortunately for us up to now vehicle engineers have been hesitant to sign off on this particular modification because they dont understand how the airbag system work and (B) they are reluctant to sign off on a modification that (as I have been told by 2 different engineers in the past) may contribute to the death of a vehicle occupant in an accident by affecting the deployment of the airbags, and they are not prepared to stand in front of a judge and explain why they signed off on a dangerous modification.
    The truth is, the modification is not dangerous if dont properly and has been done for a while now is both Europe and South Africa.....some places in Europe are even engineering 4" bodylift's (100mm) without suspension lifts, and being TUV Certified.
    I'll begin with the location of the bodymounts on the Hilux and then continue with the information you will all need to put forward to your vehicle engineer of choice to consider for a bodylift for a hilux.
    Location of Hilux Bodymounts
    Bodylifting the Hilux Vigo -37767
    NOTE: NOTE: The front two factory body blocks as seen on the diagram above are 50mm OD and the rest are 76mm OD, meaning you must use the same diameter replacement blocks as factory or larger otherwise the weight of the cabin is supported by a mount smaller than the factory. This could result in the floor pan cracking or worse, the mount joining you inside the cabin from constant pounding on dirt roads.
    I'll now get into the document that myself and Rod put together that you will all be able to use in the future-
    Hilux SRS Airbag system (April 2005 on)
    The vehicle is equipped with a Supplemental Restraint System (SRS), which consists of a steering pad, front passenger airbag, seat belt pretensioner, center airbag sensor and front airbag sensor.
    The location of these items is shown in Figure 1 and Figure 2, Below:
    Bodylifting the Hilux Vigo -37768
    Bodylifting the Hilux Vigo -37769
    The schematic for the SRS components shown above are outlined in Figure 3 below:
    Bodylifting the Hilux Vigo -37770
    Operation in case of front collision
    When an impact that is larger than a predetermined level occurs in the highlighted area in Figure 4. the airbag is deployed automatically.
    Bodylifting the Hilux Vigo -37771
    The center airbag sensor deceleration sensor uses the front airbag sensor's deceleration sensor signal to determine whether or not to activate the airbag.
    The center airbag sensor safing sensor is designed to activate at a deceleration rate that is lower than that of the center airbag sensor deceleration sensor. When the safing sensor and deceleration sensor turn on simultaneously, current flows to the squib and the airbag deploys. This is shown graphically in the diagram below.
    Bodylifting the Hilux Vigo - center airbag sensor assy
    When the vehicle is in a collision and the shock is greater than the specified value, the SRS is activated automatically. The safing sensor and deceleration sensor are built into the center airbag sensor. The safing sensor is designed to be turned on at a smaller deceleration rate than the deceleration sensor. The deceleration sensor determines whether or not SRS deployment is necessary based on signals from the front airbag sensor. Current flows to the squibs to deploy the SRS when the conditions shown in the illustration in Figure 6 below are met.
    Bodylifting the Hilux Vigo - center airbag sensor assy 2
    Affect of a body lift on the SRS
    General Discussion
    It can be seen from the technical description above that all of the SRS components and the wiring shown schematically in figure 3 are located on the passenger body shell. There are no SRS components or wiring attached to the vehicle chassis.
    Therefore, there is no affect on the SRS system if the body shell is raised in relation to the chassis.
    The only possible consideration could be that the point of impact of a collision being higher where a body lift of up to 50mm is considered. However, it is noted that raising the point of impact by the same amount can just as easily be achieved by a 50mm suspension lift that fully complies with the suspension travel requirements of VSR 8. The point of impact in a frontal collision can also be affected if the vehicle is airborne at the time of impact. This is quite probable where a vehicle leaves a built up roadway and collides with a stationery object within the shaded areas of Figure 4. Under these conditions, if deployment conditions are met, the SRS airbags will deploy regardless of whether a body lift is installed in the vehicle or not.
    Steering
    The steering wheel and column contains two SRS components. The spiral cable and the steering pad containing the driver’s side airbag.
    These components are not affected where a body lift is installed as the spiral cable is designed to accommodate extension and compression of the steering shaft and the adjustable height steering column. Whilst a slight alteration in steering column angle may occur because of the body lift, this is within the limits of the adjustable height steering column. Airbag deployment is not affected by extending the steering shaft and the relationship between the steering pad and the driver remains within normal ergonomic limits that are expected for drivers of different physical characteristics.
    Where the steering shaft need's extending, (eg. for body lifts 40mm and over), it is recommended that the steering shaft be extended by using a splined extension similar to the one shown in figure 6 below at the base of the steering shaft:
    Bodylifting the Hilux Vigo - steering shaft extension
    Components needed for 50mm (2") Bodylift
    NOTE: The bolts are M12x1.25 and the factory bolt length is 145mm so add your desired block length to that
    Quote:
    2 x 50mm diameter x 50 mm high HDPE (high density polethelyene) or aluminium blocks
    4 x 75mm diameter x 50 mm high HDPE blocks
    6 x 50mm diameter x 75mm blocks for raising the tub
    4 x 50mm square tub spacer brackets for supporting the raised tub in between the bodymount block.
    6 x 195mm M12 x 1.25mm Grade 8.8 high tensile nickel plated bolts with nyloc nuts and washers to suit
    4 x 8mm (or 10mm) radiator spacers with two holes drilled 5omm apart, (one could have a tapped thread, but nyloc nut would do. Refer to Offroad Factory's photographs below.
    Notes on application:
    Supplementary Restraint system (SRS)- not affected - produce documentation above if queried.
    Steering - not affected
    Brakes - not affected.
    Don't use the black 8.8 bolts as the rust from experience in this application.
    When fitting the HDPE blocks, Sikaflex them to the body to get rid of squeaks.
    Appendices
    Note: Alot of this information is cut and pasted from Newhilux.net - The Ultimate online Hilux community!
    Below I have listed experience comments from people fitting bodylifts to their Hilux's aswell as pictures for your reference.
    Photographs of Offroad Factory's Bodylift Installation
    before
    Bodylifting the Hilux Vigo -37772
    after
    Bodylifting the Hilux Vigo -37773
    Over-Load Blocks fitted to the tub
    As you can see Offroad Factory just used square tube to support the tub crossmembers
    Bodylifting the Hilux Vigo - 1576905
    Bodylifting the Hilux Vigo - 1576917
    View of Body sitting higher above the radiator
    Bodylifting the Hilux Vigo - 1576908
    Note: In hotter climates like Australia it may be necessary to fill in the gap above the radiator to ensure maximum airflow through the radiator core by a piece of oil resistant rubber sheeting or a block of foam (both available from Clark Rubber) so keep an eye on the temperature gauge to ensure your car is not running too hot after the body lift. Offroad Factory did not find this an issue in Germany.
    Radiator Drop Bracket
    Bodylifting the Hilux Vigo - 1576909
    quoted by Offroad Factory
    4 spacers for the radiator to keep it in the stock location compared to the engine. This saves headaches with the cooling hoses and the fan shroud.
    Body Lift Block Fitted on Mount Behind Front Guard
    Bodylifting the Hilux Vigo - 1576911
    Body Lift Block Fitted at rear of Cabin
    Bodylifting the Hilux Vigo - 1576912
    Body Lift Block Fitted at Rear of Tub
    Bodylifting the Hilux Vigo - 1576913
    Shift levers don't need any work at all. They fit nice and easy as before.
    The body mount blocks are 2 different sizes. The small ones you see in the pics are under the bed and the front (left & right from radiator), the 4 main body blocks are 75mm diameter. The front (radiator) ones have to be smaller in diameter in order to fit in the gap. The ones under the bed are just the same size as the bed supports.
    As for the gap, we'll test drive it through the next year and get results from the customer. As soon as he sees temp problems we will fill the gap with a rubber strip. On the other hand, with the stock grille the gap is not even really open.
    Bull's Build-Up
    NewHilux.net • Login
    Quote:
    I managed to spend most of last weekend on the ute, put the lift blocks in and test fitted the 35"s. Didn't worry about the 2" blocks, just went straight to the 3". No major dramas, the brake and fuel lines had plenty of length as did the handbrake and trans cable. One vacume line needed lengthening and an earth on the back of the transfer case needed turning around. The radiator was fairly straightforward, I didn't even pull it out. The plastic side straps come off with 3 bolts and I used 30x30 angle to mount them 75mm lower. There is a mounting tab on each strap that locates the radiator when installing and these had to be cut off. That's about it. Has to be the easiest body lift in history. The steering column extension had me stumped but I worked out how to do it on the flight home. The Marks 4WD steering extension is too short but if I make my own I should be able to get the uni in the right spot.
    Quote:
    I finished putting the lift blocks in very late so apologise for the dark pic. I threw the 35s on the front to see how they looked before I went to bed. This is at ride height with the stock suspension. I'll put off getting the new springs until it's final weighed so I get it right.
    Bodylifting the Hilux Vigo - scaledphp?server238
    Quote:
    The intake hose from the airbox to the turbo was too short but it looks like it was made to be cut up. It even has a couple of spots for hose clamps. This is on the ute now but it's about an inch too short so I have a longer stainless piece to replace it.
    Quote:
    You need 6 blocks.
    Some South African Hilux's
    60mm bodylift, 40mm suspension lift, 305/60x18 KM2's
    Bodylifting the Hilux Vigo - RS DSC00083
    Bodylifting the Hilux Vigo - RS DSC00082
    Bodylifting the Hilux Vigo - RS DSC00081
    Bodylifting the Hilux Vigo - RS DSC00079
    Another Blokes experience bodylifting his hilux-
    Hilux 4x4 Off-road Forum - View topic - 2005 Hilux D4D 4x4 lift project
    Quote:
    So the body lift is almost done.....
    Took the old bolts and steering shaft out on Sunday and got new ones yesterday. The steering shaft is still with the welders. Hoping to get it back today! Can't wait!
    In the end I had to do the following mods to accomodate my 50mm body lift.
    1. Then when fitting the lift blocks at the back, the fuel filler pipe also had to be extended, but i was able to do this by getting some extra play out of the current pipes. Had to make a little relocating bracket for the filler pipe to fit properly in the fuel flap housing....(there where you goo diesel into the car)
    2. Two of the load bin's 6 mounts require the bolts to go from the top down to the bottom and cause i now have longer bolts, couldn't get this into the hole, cuase the loadbin is to close to the ,ount, so have to bash that a bit and dent the load bin up a bit to get the bolts through.
    But was all fun. Hopefully will get the steering rod back today and fit it tonight.
    Ok the lift is in a looking good. My low range gear lever is rubbing however against the body so have to have a look tonight how i'm gonna allign that.
    Didn't have to dent the loadbin to fit the bolts of the front most body mounts. All I did was get slightly shorter bolts and lift the bin a bit higher in the air and in they went no hassles.
    It's better to get 40mm longer bolts for the 50mm lift and in some places i still had to add an extra washer here and there.
    I was able to refit my front bumber with a slight nip & tuck at the bottom. Had to cut about 3cm out the bottom middle of the bumper (still the original Toyota plastic for now) to get it to allign. But all in place now.
    Only thing I'd like to change is my rear Onca bull bar/tow bar. It's now sitting a bit lower (in relation to the back) but not sure how easy that'll be. Might just give them a call and see what they can come up with.
    Gonna go see Darryl over lunch time to discuss the suspension lift!
    Ok, took some pics over lunch time in the parkade (with the cell phone). tjol lighting, but anyways.
    The ve-hii-icle really does look the part now. Took a bit getting used to but the handling dynamics honestly remained unchanged. I don't notice any body roll at all.
    Parked next to a standard Hilux in the parkade yesterday and it really does look much higher.
    I went to go chat to Darryl from Mikem yesterday so soon as they get my parts and have a time slot, "die Brakkie" is going up another 50 -60mm. Plus i'll have the bilstein struts so i can adjust the height. (e.g like when i oneday after this can afford to add a front bumper....love the burnco bar for the Vigo Lux, by far the best looking I've ever seen here in SA!)
    Bodylifting the Hilux Vigo - filephp?id8158
    Bodylifting the Hilux Vigo - filephp?id8157
    So the front went up 40mm (for now) and the back by about 65mm
    Bodylifting the Hilux Vigo - filephp?id8552
    Another one -
    Quote:
    Here is a few pictures of the last "lift" job Allan did on a 2006 Hilux 4.0
    He did the following:
    50mm body lift,
    50mm suspension lift (TJM suspension fitted)
    The tyres are BFG Muds 32 X 11.5 X 16 with the new tread pattern. Because the BFG's are mounted on the original 7.5" Hilux rims, the circumference of the wheel is more than the circumference on Kaspaas' 33"s on 10" rims.
    Bodylifting the Hilux Vigo - hiluxlift019
    Bodylifting the Hilux Vigo - hiluxlift015
    Bodylifting the Hilux Vigo - hiluxlift012
    Bodylifting the Hilux Vigo - hiluxlift005
    Bodylifting the Hilux Vigo - hiluxlift001
    All done, drives exactly as per stock besides the gearsticks being lower (which I prefer).
    Most of it went smoothly....steering is a issue with going to 50mm.....and I reckon even 40mm wouldn't be 100% safe (without doing mods).Twisty here is reffering to the steering shaft spacer
    Radiator drop brackets worked great, made out of 6mm stainless stell, with a tapped top hole and counter sunk S/S allen key bolt for the bottom one that goes into the std. radiator mount. Kane (mates workshop I did it at) will be able to make them for others if needed.
    Bodylifting the Hilux Vigo - 19062009153 Gsized
    Radiator Drop Brackets Fitted-
    Bodylifting the Hilux Vigo - IMG 2811sized
    And how the radiator now sits with bodylift fitted-
    Bodylifting the Hilux Vigo - IMG 2810sized
    Fuel filler chassis mount....didn't raise this the full 50mm, just did it enough for the cap to work without touching the hoses.
    Bodylifting the Hilux Vigo - IMG 2812sized
    Cap does sit a little lower now, but works fine.
    Bodylifting the Hilux Vigo - IMG 2813sized
    Front bumper didn't need any mods to re-fit, is just missing a few of the std clips etc that hold it on, but its still solid as.
    And how she sits now with the bodylift fitted and everything else standard-
    Bodylifting the Hilux Vigo - IMG 2815sized
    Bodylifting the Hilux Vigo - IMG 2814sized
    Bodylifting the Hilux Vigo - IMG 2816sized
    quoted by deonsa
    Hey guys, that light blue hilux is mine. (the one mmaaxx posted above)
    I first did a 50mm body lift and now in the process of doing the suspension lift.
    Ok, to give you some info:
    1) What i did wrong was not move the radiator, instead i cut the cowling, cause in a stuper, when looking at dropping the radiator i thought the cross memeber was way too close - that's cause i looked at it before the body was lifted, so after the body is lifted 50mm there's plenty of space to drop the radiator. Drop it!!
    2) There's one pype in the engine bay that needs lengthening though - when standing in front of the car looking into the engine bay, it's connected from the lower right hand side of the engine (about 30cm below the power steering reservoir and runs to a steel pipe connected to the body of the car, roughly under the battery. Let me know if you need more info as to which one i'm talking about and i'll try load pics.
    3) My fuel filler pipe was a bit short, but there was enought play at the diesel tank side so i just pulle dit out a cm or 2 and re-clamped it. Had to then make a little steel bracket to re-allign where the fuel filler bracket gets attached to the chassis.......quite close to the tub's one body mount. Just make sure you remove your fuel filler when jacking up the car, as the cap will pull of and might break.....
    4) Another must (on the manual, dunno about the auto) is to do a bit of grinding for the transfer case lever.
    If you lift it, you wont be able to move it! so you gotta remove the centre console and then remove the rubber covering that sort of keeps water and dust out of the cab, and then grind/saw/file the body away. I had to remove a piece around 5 x 2 cm from the left of the transfer case.
    Other than that, the only thing i couldn't and wouldn't dare do my self is extend the steering column/shaft that runs from the firewall down to the steering rack.
    I had it extended by 45mm at an enginerring/welding co....That cost me around $70 (aus) if i convert.
    So that was the only thing i had to wait for. Took me 2 days. Probably around 10 hours.
    Best thing is to check and listen when you jack. Rather safe than sorry.
    Now busy with the suspension...........
    Note: For Further Explanation on what is a bodylift? What does it do to a vehicle? and How does it affect vehicle performance, ability and handleing, please check out the following link at the 4Crawler website -
    4Crawler Offroad - Custom Body Lift Kits
    sourcehttp://www.vehiclemods.net.au/forum/viewtopic.php?f=26&t=34
    RIP
    060276's Avatar
    May 2009
    27
    1,859
    43 Post(s)
    uuuuuuuuuuuuuuuuufffffffffffffffffffffffffffffffff ffffffffffffffff ..too much nice stuff to read...........
    Umer Siddiqui ... Inline Six .... ** 2JZ-GE **
    Sarosh_Ather's Avatar
    Feb 2009
    23
    2,811
    that black1 wid 305`s is AALA
    i would love to have such an offroader!
    Ghilzai's Avatar
    Oct 2009
    Select City
    42
    282
    It all toooooooo technical for me ... I loved the vehicles though wud love to drive them.
    Ghilzai
    The possibilities are endles ... all you need is a 4x4
    turbolover's Avatar
    Oct 2006
    41
    1,099
    Very useful info indeed. These aussies are masters in such thing. Complex but cheaper alternative to a suspension lift. Question remain...who in pakistan do this?
    thanks 4 sharing
    Truckin' Time with a Surf, because life is too short to fix Land Rovers
    fastoriel's Avatar
    Jul 2006
    27
    7,158
    its very technical as @ghilzai bhai said ... n i cant understand it either ...
    Levels are not achievd but levels are created...
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    what i dont' get is why go through all the trouble of lifting the body when you can get lift kits which will raise the suspension and give the entire vehicle better road clearance?
    doing the above only lifts the body and not the entire chassis. there are many companies out there which will do lift kits, infact there is a vigo in ISB which has been lifted but not like this, it actually has a 3 inch lift kit installed and the results are amazing!
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Been there, done that! body lift is unpractical and you have to go through a lot of minor mods to successfully do it, while a suspension lift is far more better and mostly can be done for a slightly higher cost. The only point of having a body lift is to easily fit bigger tires without cutting the body while saving some money on replacing major suspension components.
    People usually buy a 3 inch suspension lift, and add a 2 inch body lift to make way for 36-37 inch tyres... but they always end up saying "whats that rubbing underneath?", overlooking the fact that the tire is hitting the wheel well.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    If one wants to lift, then lift big and wide.
    Everything has to grow in proportion, as lifting a 4x4 would raise the centre of gravity and increase the chances of a tip-over.
    As for a Hilux, well its already failed the Moose Test, Twice ! so one should really think about lifting that.
    Some lifts are simply preposterous.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    virtual_law's Avatar
    Jun 2005
    392
    It all looks great and dandy in pictures, but I wouldn't want all that effort to be done only to end up having my unsightly underpinnings contrasting against the beautiful body work.
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Where would one find the bushings for the body lift? Good info though Qwerty.
    MMC
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
  12. #12
    Basharatu's Avatar
    Mar 2007
    Basco
    2,323
    23 Post(s)
    Quote Originally Posted by raohamid View Post
    MMC
    @MMC, you have enough lift on Gen-1, u can take my mog if u want more ground clearance
    When Nothing else do the Job "ҐЄຊ๓ પฑḭ₥φ౸" has the solution. http://www.facebook.com/team.unimog
  13. #13
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by Basharatu View Post
    Lol. Ok. Tested it in Lahore. Will fill you in Bash.
    MMC
  14. #14
    CrashD's Avatar
    Nov 2006
    39
    5,169
    51 Post(s)
    just get a lift kit which is much better result orinetated and suspension I had a Hilux tiger in blue and grey which had a lift kit and snorkel fully 4x4 style with tyres and rimz! was a pain to get into and out of it didnt prove practical at times in city but ppl did move out of the way!! I have owned number of vigos and hilux and nothing beats driving one!
    BUG ME AND I WILL CRASH INTO U!
  15. #15
    info131's Avatar
    Nov 2012
    36
    17
