Results 1 to 14 of 14
Thread: Leaf to Coil Springs ~ Modification
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Default Leaf to Coil Springs ~ Modification
    Has anyone thought of and / or gone for a conversion to coil springs from leaf springs in a Hilux or any other pickup ?
    Can it be done ?
    What are we looking at in terms of modifications ?
    Do you think its a stable solution to an otherwise stiff and bouncy ride ?
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Hey Sarmad, how r u man?
    For the conversion i think you should also talk to Afzal Sahib, he owns a workshop and do the metal work/conversions in rally vehicles of most of the KHI guys. I had his mobile number but cant find it in my set now. Since Afzal Sb. is a famous personality in rally world, i am sure you can get his number from Sajid Dadaboy or Maj Osman(Mitsuman). You can also contact my friend Rasim 0305-222-6171 who is a customer of Afzal Sb.
    Dec 2007
    40
    1,599
    Quote Originally Posted by saidhi View Post
    Hello Qasim, I'm fine thank you, how about you ? You Ok ? !
    If its the same Mr. Afzal you are talking about then I think I have his number saved as Afzal Snorkelwala ending with 528.
    I spoke to him once regarding a snorkel for my Hilux & he had a decent price for it.
    How's the dear old Jimny ?
    deadly's Avatar
    Mar 2006
    30
    260
    Hello Sarmad,
    Recently I have changed my cj-7's leaf to SSR-X Coil springs in front and back tube I used to SSR but there are Leaf spring's at the back ! Haven't test it yet on off road but on road working pretty fine ... tho I wasn't a easy task but I glad I'm first in my gathering to do such an alteration
    If The Desert Could Speak ... It Would BEG for MERCY. [ J E E P ].
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Good Topic !
    There have been a number of leaf to coil conversions on CJ5s/7s in Rawalpindi market since 2003/2004, usually coupled with the 1KZT engine conversion. I believe TLC70 parts were used in most of these though some may have used SSR stuff. Not sure if anyone has tried it on TLC40 but have seen it done on the net.
    Have not seen or tested any of these myself but my mechanic and bodywork Ustads never encouraged me to pursue this option despite a few half hearted attempts. From what I understand, the conversion itself is not very tricky but nevertheless quite messy and probably quite easy to muck up given positioning and welding. Key issue is that Toyota coil springs are for significantly heavier vehicles and getting the precise suspension geometry on coil springs is quite difficult (as IJC members have recently witnessed ) . Hence its not surprising that most local conversions are said to have had high speed handling issues, though with much cushier rides on bumpy roads.
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Janj has done it before, though it was coil to leaf... ask him...
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Quote Originally Posted by sarmadqureshi View Post
    The bouncy ride in pickup trucks is because of stiffer and more leaf springs at the back. That ensures that when you put some weight in the back (to fulfil the purpose of a pickup truck), the rear will not sag down. I think, prior to getting into tricky leaf to coil spring modification, you should try on a softer set of leaf springs at the back specially.
    The leaf vs coil spring performance is a debatable topic though and you can find lots of writeups on this at google.
    Ehsan
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Lessening a few leafs does the job...
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Dec 2007
    40
    1,599
    Default Its the REAR suspension.
    Guys, I'm sorry but I guess I didn't clarify it in detail. What I'm talking about is the rear suspension of Hilux / Vigo being replaced to a coil spring.
    Thanks Ehsan for the detail.
  12. #12
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Sarmad,
    Afzal Sb has supplied many snorkels too, i think its the same person, talk to Rasim he will be able to confirm the contact details of Afzal Sb.
  13. #13
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    @ sarmadqureshi, brother any latest on the subject issue? Do share if any information gathered as it sounds a new thing and would be a new experience.
  14. #14
    Dec 2007
    40
    1,599
    Quote Originally Posted by noman8ff View Post
    Noman, the latest is that now I know that it can be done and have seen how its done ...... on to doing it would definately bring about more knowledge on it.
    As for actually doing it, I need to get a donor vehicle 1st, dad's gonna kill me if I touch the Hilux with this mod.
    The other thing I have learnt is that if the vehicle is used for any kind of loading and runs on dirt tracks, leaf springs still win hands down.
    Must have a look at the link posted by ehsankiani above, its great knowledge and a great find by Ehsan.
