Results 1 to 3 of 3
Thread: Leaf springs or coil springs
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Default Leaf springs or coil springs
    Before i ask the question, please note that,
    1. We are not discussing any specific brand.
    2. We are not going to discuss any front or rear suspension differences.
    3. We will only discuss the stock, standard suspensions and not the modified suspensions for hardcore offroading in specially modified 4X4's.
    Now i want you to put across your knowledge as which would you prefer in terms of
    1. Strength.
    2. Top and bottom reach or the tyre.
    3. Reliability factor.
    4. Comfort.
    salmanchaudhry's Avatar
    Feb 2009
    46
    132
    Default Suspension setup
    First of all I would add that I feel that this discussion must be expanded to the Suspension set up. Logic is that springs work in conjuction with suspension geometery and other hardware (axles, locating arms etc) to give it the feel and strength you are talking about.
    My suspension of choice is rigid/ solid axles with coil springs. To elaborate further I would like to add that variable range/ tension coil springs with variable damping shocks work best. The usual setup we see in bikes and cars do have variable rated springs with only one setting for the shocks. In high performance setups not only the springs progressively get stiffer as they are compressed but also the shocks have 3 or 4 stage valving (soft-medium to hard) that add resistance as they too are compressed.
    Second part of discussion deals with the amount of axles articulation engineered into the suspension geometry. The more the articulation the more a wheel is able to travel up and down and follow the terrian while keeping the vehicle straight. In good 4x4 with rigid axles and coil springs front and back axles are able to reach extreme angles while the vehicle is fairly straight. This ensures maximum traction, control and safety during extreme angles, especially over rocks and boulders.
    In terms of comfort and reilability coil springs win..any time. Leaf springs are great for exteremly heavy loads and very durable, however, as leaf springs do not have multiple components they are still more reliable.
    Defender setup rigid axles with coil springs is a good setup in my opinion.
    The above is only my opinion. I am sure experts out there can do a much better job in explaining springs and suspensions.
    Feb 2009
    46
    132
    In terms of comfort and reilability coil springs win...any time. Leaf springs are great for exteremly heavy loads and are very durable durable under extreme loads, however, as COIL springs do not have multiple components they are still more reliable.
