Results 1 to 8 of 8
Thread: 1992 Toyota Prado 5 Door
    asif20's Avatar
    Mar 2010
    41
    Default 1992 Toyota Prado 5 Door
    Hey Guys, I am getting a 1992 Prado 2004 Registered 2.4 L Diesel Engine, very good condition for Rs 9 Lacs. Got the vehicles checked from Mechanic and Body Shop, and everything ok. Is this the right price for this vehicle? Will 2.4L Diesel be ok or should I search for 3.0 L Diesel?
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Asif, it all depends on what your use is of the vehicle. 9 is a decent enough price. Qaisrani has a 2.4l Prado he would be able to give details. As from my experience of driving a 2.4 (nvr owned one though) as along as its on the tarmac its fine, off it, it seems to be bit short of power.
    People new to the 4x4 arena may not even feel that, unless they comparitively drive another powerful vehicle in the same conditions and then switch back immediately to a lessor one.
    The 3.0 has a 1KZ in it and I would not suggest that unless you have no issues regarding fuel.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @asif20
    The price is attractive but the 2LT should be a big NO.... 1KZ, anyday!!!!
    MEN DO IT AT DAKAR!!!
    asif20's Avatar
    Mar 2010
    41
    Thanks for your input. Also saw one 1992 Model 2007 Registered, Black Color and very good condition. Seller not going below 13 Lacs. Is it a fair price?
    asif20's Avatar
    Mar 2010
    41
    I don't know much about 4X4. Anyone who have used Prado 1993, can u pls explain how to use 4X4 and when to use Hub lock button.
    Thanks
    nomi1234's Avatar
    Jun 2009
    1,238
    9 Post(s)
    Quote Originally Posted by asif20 View Post
    Thanks
    Asif, to engage the 4x4. first you need to press the Hub Lock Button, it should be on the right hand side of the steering wheel. then press the H4 button next to it. Now your ride is in Hi-4WD.
    To disengage 4x4, first press the H4 button then the hub lock button.
    If you need more power (useful only in extreme offroading conditions) you can engage Low-4WD. you can do this by first locking hubs with the button and then use the small Gear shaft to shift to L4
    Your 92 prado should also have a knob on teh left bottom side of Steering which says something like Off-RR. this is a diff lock knob. once you start doing some serious offroading you will need this. i won't confuse you with it at this point.
    I may get Lost But I don't get stuck!
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Quote Originally Posted by nomi1234 View Post
    Not all Prados come with front and rear lockers..
    Asif, there were some interesting bj/fj 60 in sunday's Dawn. DId you check them out? I love the size and power of the 60 series but its not something that you can use on a daily basis, also parts and resale maybe an issue.
    92-94 Prado range from 8 to 13 lakhs, try to go with 1kz.. nothing like having bit of a power at your disposal.
    Pakwatan Explorer
    R.I.P. Follow
    topracer's Avatar
    May 2006
    36
    2,652
    1kz or some think in petrol no way 2l, i have throw out my 2l and swped 1jzgte.
