Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By IsbCap
  • 1 Post By aviator_12
Thread: A Question for Offroaders?
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Default A Question for Offroaders?
    Hi all,
    Few days ago, I came to know about All Wheel Drive Japanese corollas like LX Limited (Indus shape), 2.0D model 1995-96(Indus shape), and 2.2D station wagon model 1998-99. Similarly corolla X 2000 to 2004 and Corolla X fielder (state car) are also available in AWD or 4WD.
    My question is that whether they are available in 4x4 in Pakistan or not (although I have seen many of their front wheel drive versions here). OR has someone imported them in recent past years. I want to buy any such car, bcoz I am in a need of it. I was searching for a pajero Jr 1100CC but now I am searching for 4WD Corolla with manual transmission when I heard about its AWD version. If someone has info about their performance for offroading or pics of any central differential or gearbox of such cars, then pliz do post them.
    Your cooperation will be highly appreciated. Thanks.
    Sarosh_Ather's Avatar
    Feb 2009
    23
    2,811
    never heard bout`em
    but the pros know better!!
    instead buy a pajero jr. its a pocket rocket!
    as 4wd/awd corollas(if they happen to b) wont b that gud in offroading!
    afaik the 74-76 were the rwd!correct me if i`m wrong!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    I remember seeing an AWD/4wd Corolla in 1988-1992 shape buts that was a long time back. I understand that Corolla still have 4wd versions in Japan going all the way back to the 1973/4 models:
    4x4 Corolla - rollaclub.com
    Offroad performance should be pretty decent given that all RWD Corollas ('74 to '82) I've been in were pretty decent rides on hilly tracks. At times, I have found myself wondering if its possible to put on a 4WD transmission on an Indus Corolla as I'm pretty sure that with a hald decent lift you could take it to an IJC event..... and probably make it back too
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Corolla X Fielder AWD & FWD are available here in the market. Not many takers though & few cars.
    You can check for Orion Motors, DHA Phase 1, Karachi in the Auto Pages link above. He has the largest # of station wagons here and I have seen AWDs & 4WDs at his place.
    As for the offroad capability, not much ! as there is the clearance issue. It'll take you from point A-B on a muddy slushy track without the need of a tractor pull, but thats about it. Yet to see it run on sand like a Subaru Impreza AWD
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    You can even make it over the Babusar Pass with a decent lift For those who missed Janj's encounter with the Corolla 1.3 that made it across: https://www.pakwheels.com/forums/roa...r-top-4-days-3
    A Question for Offroaders? -1014763
    fihsak's Avatar
    Aug 2004
    Select City
    32
    1,749
    19 Post(s)
    2 Thread(s)
    @ameerusman
    there are 'yota full time 4wd or AWD cars in pakistan & i personallay have seen n driven a '88 sedan AWD 1.8 D belonging to one of my relative, it was having superb grip and braking as it was having Disc Brakes in the rear too
    Amazingly some of the 88 corolla sedans also come with Rear Difflock option as i have a Button off a 88 dash board in Shuba that says "PULL DIFF LOCK"
    U can find corolla X too in AWD but have to search for it
    if u want it in budget then u can go for a Alto 660 cc AWD
    But remember these AWD vehicles are for highways & for Snow/ slippery roads where more traction is needed, u can use them for offroading but U have definitely to modify most of its suspension n that too just to a certain limit
    Best of Luck for the Hunt
    Regards
    When Nothing Else Work, Team Unimog has the Solution....
    Dec 2007
    40
    1,599
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Last year i visited northern areas. These 4x4 corollas are very common there. Every 2nd car you'll find there is a 4x4 corolla.
    I loved the shape. Have seen only one of them in Isb.
    Btw all those are NCPs and only driven in those specific areas.
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    This is what it used to look like.
    A Question for Offroaders? - 47498attach
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Another snap:
    A Question for Offroaders? - 47499attach
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    i have also driven one couple of years back and i would agree with Fishak..its an amazing vehicle..a bit heavy on fuel though. if you intend to offroad then i would suggest you stick to Paj Jr or a substitute, unless you find a decent 4wd rolla and are ready to modify the suspension...but then you will be compromising on the road grip and handling part.
  12. #12
    shahbaz_79's Avatar
    Oct 2007
    37
    406
    Bhai Logo ,
    Almost all of the current sedans and mini japanese cars do come in 4x4 mode in japan, Simply because their are lot of hilly areas in japan almost 75% of total land area thats why they make 4x4 version of almost every car ranging from 660 cc Alto to 4300 cc Toyota Crown.
  13. #13
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Thanks to all for nice and valuable infos.
    @fihsak
    I do not need this corolla for offroading. I have only one problem and that is "About 10 meter track near my home is a muddy place, where my 2.0D indus Corolla 2001 sometimes tries very hard to cross that part of muddy track". Although it crosses that track and there is no need of extra pull, but sometimes I feel that I should go for a 4X4. Anyways searching for a Jr as well as 4X4 Corolla.
  14. #14
    aviator_12's Avatar
    Nov 2006
    41
    590
    Quote Originally Posted by IsbCap View Post
    The fav car of SUICIDE BOMBERS in those areas
    HONDAS are like GIRLFRIEND and, TOYOTA a life partner always with u even going is tough..
