Page 1 of 9 123 ... LastLast
Results 1 to 20 of 178
Like Tree27Likes
Thread: Restoration of Lazzaz
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Question Restoration of Lazzaz
    After her last glorifying act of winning the night mud rally, Lazzaz died on the way back from Lahore. She was a heart patient and got real excited after winning the rally and hence the heart failure.
    Below are the pictures of her after winning the rally.
    Restoration of Lazzaz -67786
    Restoration of Lazzaz -67787
    Restoration of Lazzaz -67788
    I was opting for 3C turbo engine but due to the scarcity of diesel engines in the market, 3S will be the new motor.
    Engine has been purchased and hopefully, I will be getting Lazzaz back sometime next week. What should be must to do/consider for replacing 2C turbo with 3S????
    Has anyone done this swap? Do I need to change the gears? Current setup is Rocky 5 speed gear and differentials.
    After the engine, next step will be suspension upgrades to take the abuse in rally conditions. What needs to be done to improve stability at high speeds? Will dual shocks on all four wheels help???
    Any kind of valid/invalid wild ideas and suggestions are highly welcomed.Restoration of Lazzaz - 67786
    Restoration of Lazzaz - 67787
    Restoration of Lazzaz - 67788
    Believe half of what you see and none of what you hear.......
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Good luck for Restoration
    Imran Iqbal
    DCcoolguy's Avatar
    Feb 2009
    Sialkot
    25
    5,694
    31 Post(s)
    Good luck bro!
    <BLACK SMITH>
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Unhappy
    Poor Lazzaz, its sad to see a winner die out like that, but then again it was no joke winning that achievement either.
    As for the engine, enlighten a bit as to what vehicle came equipped with it and what currently do were you running in it ?
    As for your suspension, YES you can put in dual shocks at each end, but keeping the existing spring leaves may stiff the ride to a great extent. Suggest you lesson the # of springs and add an aux shock. Reduce the leaves only when you feel the ride's of standard.
    Good luck.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    3S is toyota 2 liter engine. Different variant are there, 3SFE, 3SGE etc.
    Details from Wiki below:
    S-FE 87-90 86.0 mm 86.0 mm 9.8:1 1998 cc 90 kW@5600 rpm 169 Nm@4400 rpm -SS1 (ST202)
    3S-FE 87-94 86.0 mm 86.0 mm 9.8:1 1998 cc 85 kW@5600 rpm 162 Nm@4400 rpm Equipped with catalytic converter
    3S-FE 95-98 86.0 mm 86.0 mm 9.8:1 1998 cc 96 kW@6000 rpm 178 Nm@4400 rpm Refined valve timing and ECU settings, introduced with Carina E (T19) model
    3S-FE 1998-2000 86.0 mm 86.0 mm 9.8:1 1998 cc 94 kW@6000 rpm 178 Nm@4400 rpm Slightly less power with better torque characteristics. Stricter pollution control. Introduced with the new Avensis (T22) model
    3S-FSE 2001-2003(?) 86.0 mm 86.0 mm 9.8:1 1998 cc 110 kW@6000 rpm 192 Nm@4000 rpm D-4 (Direct injection), VVT-i (only available in EU/Japan markets?)
    3S-GE 85-89 86.0 mm 86.0 mm 9.2:1 1998 cc 103 kW@6200 rpm 175 Nm@4800 rpm Celica 2.0 GT-i 16, GT-R (ST162)
    3S-GE late-89-93 86.0 mm 86.0 mm 10.0:1 1998 cc 115 kW@6600 rpm 186 Nm@4800 rpm Celica 2.0 GT-i 16, GT-R (ST182/ST183), MR2 (SW20)
    3S-GE 94-98 86.0 mm 86.0 mm 10.0:1 1998 cc 137 kW@7000 rpm 192 Nm@4800 rpm Celica GT, SS-II (ST202), MR2 (SW20)
    3S-GE 1998 only 86.0 mm 86.0 mm 11.0:1 1998 cc 150 kW@7000 rpm 210 Nm@6000 rpm Celica (ST202), MR2 (SW20)
    3S-GE 1997 - 2005 86.0 mm 86.0 mm 11.5:1 1998 cc 156 kW@7500 rpm 220 Nm Altezza, Caldina GT
    3S-GT (503E) 1987-199? 89.0 mm 86.0 mm 7.0:1 2140 cc kW (560 hp) Nm (471 ft·lbf) @5500 rpm 87C, 88C, Eagle HF89, Eagle Mk III
    3S-GT (503E) 1987-1989 89.0 mm 86.0 mm 7.0:1 2140 cc kW (680 hp) @8500 rpm @5500Nm (471 ft·lbf) @5500 rpm 87C, 88C (Le Mans setup with CT26R turbocharger)
    3S-GT (503E) 1995-1996 89.0 mm 86.0 mm 7.0:1 2140 cc kW (680 hp) @8500 rpm Supra GT JZA80 (Le Mans setup, Garrett turbocharger with 55.9mm restrictor)
    3S-GT (503E) 1997 86.0 mm 86.0 mm 7.0:1 1998 cc kW (480 hp) @6800 rpm Nm (471 ft·lbf) @4500 rpm Supra GT JZA80 (JGTC setup with 45.3mm restrictor)
    3S-GTE 86-89 86.0 mm 86.0 mm 8.5:1 1998 cc 136 kW (182 hp) @6000 rpm 250 Nm (184 ft·lbf) @3600 rpm Celica GT-Four (ST165)
    3S-GTE 90-93 86.0 mm 86.0 mm 8.8:1 1998 cc 165 kW (221 hp) @6000 rpm 304 Nm (224 ft·lbf) @3200 rpm Celica GT-Four (ST185), MR2 (SW20)
    3S-GTE 94-99 86.0 mm 86.0 mm 8.5:1 1998 cc 180 kW (241 hp) @6000 rpm 304 Nm (224 ft·lbf) @4000 rpm Celica GT-Four (ST205), MR2 (SW20)
    3S-GTE 1999-2007 86.0 mm 86.0 mm 9.0:1 1998 cc 191 kW (256 hp) @6200 rpm 324 Nm (239 ft·lbf) @4400 rpm Caldina GT-T
    Departed soul was 2C turbo.
    (ST215), Caldina GT-Four (ST246)
    aamir567's Avatar
    Feb 2008
    Select City
    55
    11,953
    26 Post(s)
    7 Thread(s)
    Best of Luck for the restoration of Lazaaz
    -It is always Man behind the Machine.
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Sir G,
    Sirf best of luck say kam nahi chalay ga. Kuch suggestion, mushwara.................... especially on suspension part.
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    MODs, Can you please move this thread back to 4x4 section.
    wasifali89's Avatar
    Aug 2006
    Dubai
    27
    5,077
    good luck
    and i have my eyes on ur project
    (1)Austin of England, a35, 1958, 850cc,,, (2) Mercedes benz , w202, C - 180 ,,, (3) 2003 HONDA CITY,,,, (4) Triumph TRW 500cc, 1952,,,,
    Founder Follow
    HanifBhatti's Avatar
    Jul 2003
    60
    45,311
    55
    981 Post(s)
    71 Thread(s)
    Quote Originally Posted by parapilot View Post
    Topic moved
    Best of luck, Please keep us updated
    Formerly known as Libra. Founder Pakwheels.com
    Hasnain3958's Avatar
    Feb 2010
    Toronto
    24
    1,844
    best of luck
    BB pin :260DB2B9
  12. #12
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Ahsan bhai, 3S will not make it rally like.. u will miss the diesel turbo
    i have seens some 3RZ-FE's around.. they are better motors.. or check the Y-series engine.. 4Y is probably 2.2L petrol comes in Hilux.
    but as you have already bought the engine.. try it.. you might like it.. its going to be very economical
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  13. #13
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Akif,
    As per your suggestion, i have looked into the possibility of 2RZ-FE and 3RZ-FE. Both the engines are quite big and would involve a lot of modification in the body.
    3S was the only option without the alteration of body. As mentioned earlier on IJC forum, I will attempt one rally and if rally bug does bug me after the participation, I might replace the engine or get one rally specific jeep.
    Now the big question is how to get stability. bigger tires will end up eating the power and engine has to work extra hard to rotate them. I will try 265-70-15 Geolander ATS to get the feel of it after the suspension upgrades.
    Not sure what will be the upgrades though.
  14. #14
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Baba-e-Pakwheels AKA Libra, thanks for moving the thread where it belongs.
  15. #15
    imtishal's Avatar
    Sep 2006
    42
    3,881
    11 Post(s)
    I'm sorry for the departed soul..Allah usko kabarh-khanaye mai achi jaghan aata farmaye.
    jannah kitne bajaye ho ga??or qul kab hein??.
    Qaiser Pal,I have not failed.But found 1 of 10,000 ways which doesn't work.....Toyota driver "I couldn't repair my brakes,so i made my horn louder"..When i was born i was so surprised that i didn't talked to one and half year..since light travel faster then sound,people appear bright until you hear them speak..If u can't convince them,confuse them
  16. #16
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Sir G,
    Ab to jo khaya tha sab hazam bhi ho gia hay. IJC guys were with her for moral support at the time of last breath.
  17. #17
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    my prayers go out to the departed powerplant, InshAllah the next one will take lazzaz to more wins. My suggestion is for a 3S-GE (any) since it has plenty of torque and i'm against turbos on real offroaders (more to go wrong).
    I cannot comment on the suspensino as i'm not that good with offroad setups.
  18. #18
    Basharatu's Avatar
    Mar 2007
    Basco
    2,323
    23 Post(s)
    Congrats for the Big win , That's another feather in the cap of Lazaz, the old engine took U to Shimshal, did numerous IJC events & finally brought the cup home, 2C turbo ke Jayho!
    3S sounds more environment friendly option, I am not sure how would it negate the water crossings in the northern regions.
  19. #19
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    It should be a 3S-GE, saw on ein PEshawar and asking price was 50K
    Also Rocky Gear and DIff will kill the performace. Get transmission from a Townace 4x4 along iwth DIff. That will make it real high speed off roader with torque at high end which is what you need in Cholistan.
    Keep a cool head and wear seatbelts!
  20. #20
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Quote Originally Posted by spectra View Post
    vadday ustaad jee, town ace vich low ratio gearbox aya si?
