Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 178
Like Tree27Likes
Thread: Restoration of Lazzaz
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Question Restoration of Lazzaz
    After her last glorifying act of winning the night mud rally, Lazzaz died on the way back from Lahore. She was a heart patient and got real excited after winning the rally and hence the heart failure.
    Below are the pictures of her after winning the rally.
    Restoration of Lazzaz -67786
    Restoration of Lazzaz -67787
    Restoration of Lazzaz -67788
    I was opting for 3C turbo engine but due to the scarcity of diesel engines in the market, 3S will be the new motor.
    Engine has been purchased and hopefully, I will be getting Lazzaz back sometime next week. What should be must to do/consider for replacing 2C turbo with 3S????
    Has anyone done this swap? Do I need to change the gears? Current setup is Rocky 5 speed gear and differentials.
    After the engine, next step will be suspension upgrades to take the abuse in rally conditions. What needs to be done to improve stability at high speeds? Will dual shocks on all four wheels help???
    Any kind of valid/invalid wild ideas and suggestions are highly welcomed.Restoration of Lazzaz - 67786
    Restoration of Lazzaz - 67787
    Restoration of Lazzaz - 67788
    Believe half of what you see and none of what you hear.......
  2. #61
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Thumbs up
    @Parapilot Good luck Sir!!
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
  3. #62
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Latest pictures.
    Engine installed. Radiator cleaned with new outlets for smaller pipes.
    Gear is moved forwarded. Drive shafts redone as engine has to be placed at a different location.
    New battery to be installed as there is no room for big battery. Fuel tank cleaned with new fuel pump installed.
    Restoration of Lazzaz -73801
    Restoration of Lazzaz -73802
    Inshallah I will get jeep back tomorrow or the day after.
  4. #63
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Tomorrow the electrical work will be done. Radiator fan is with lathe machine guy for modification due to space constraint.
    Once all the mechanical bits are done, Lazzaz will be on its way to Ustaad Jameel Awan at city Saddar road for extra fuel tank and other mods
    Restoration of Lazzaz -73813
    Restoration of Lazzaz -73814
    Restoration of Lazzaz -73815
    Restoration of Lazzaz -73816
  5. #64
    bobby9191's Avatar
    Aug 2009
    40
    143
    Mashallah it seems better then before.....can u plz give me any idea for cost of engine swap.
  6. #65
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Bobby,
    Initial plan was 3CT, but it was not available in market and was quoted @ 95,000. 1KZTE are available @80-85K.
    Due to engine bay space limitation, 3S was the choice.
    Engine is available in market @ 45k-60k. For the engine swap in Lazzaz, I will find out the total cost tomorrow. The initial deal was 65K where the mechanic was suppose the get the jeep running. Old 2CT is also ustaad's property.
    Now looking the amount of extra work/things that ustaad had not anticipated before have come into the picture. I think, the final cost will be around 70K + cost of new battery.
    This was a hassle free deal as each and every bit has been purchased by mechanic and I will be having 15 days warranty on engine after getting it from mechanic.
    Quality of work seems quite decent.
  7. #66
    BlackOp's Avatar
    Feb 2009
    Select City
    42
    351
    6 Post(s)
    Thumbs up
    Best of luck brother sounds good as all the stuff is becoming new with engine aswell so i am seeing lazaz in action in our group very soon again Inshallah.Good Luck.
  8. #67
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Last night's activity. Storm's brand to keep Lazzaz going.
    It will be ready today and I will collect it tomorrow Inshallah.
    Restoration of Lazzaz -74649
  9. #68
    stonedsaint's Avatar
    Feb 2006
    2,453
    8 Post(s)
    2 Thread(s)
    @parapilot
    wats status bhai ?
  10. #69
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    now that is good news Para......hope she is ready for the sand run scheduled this sunday. i have to take my jero to the sugeon for some finals on the snorkel tomorrow.
  11. #70
    bobby9191's Avatar
    Aug 2009
    40
    143
    Sir...whats the progress? waiting for your ok report..............i think u will miss
    2c engine ..plz upload more pics
  12. #71
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    2C is not missed at all. Performance is much better as we are comparing around 70 horses with 137.
    Yesterday we took it to Rohtas fort with IJC and it behaved really good. Average on highway is between 12-13 Km.
    Still a lot of small thing are to be taken care of but overall, it turned out to be good performer.
  13. #72
    Ghilzai's Avatar
    Oct 2009
    Select City
    42
    282
    Congratulation as Lazzaz is up and running now ...
    The possibilities are endles ... all you need is a 4x4
  14. #73
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Quote Originally Posted by parapilot View Post
    Restoration of Lazzaz - 74649
    new engine with new lubrication,... must be alot of fun.
  15. #74
    aamir567's Avatar
    Feb 2008
    Select City
    55
    11,953
    26 Post(s)
    7 Thread(s)
    The performance of Lazaaz was excellent at Rohtaas adventure
    -It is always Man behind the Machine.
  16. #75
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default BTW : The Final Moments of the 2C
    Restoration of Lazzaz - filephp?id3725
    @Parapilot: Whats the latest??
  17. #76
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    SK,
    Engine done and performed good at Rohtas. Later had some issues with front differential (it was giving clicking noise when 4x4 was engaged), sort that out. Gear stated to cry and was having clicking noise. All the bearings were replaced with "GANIIANE" bearings. It started to give shrilling sound. 4x4 gear box was checked and later the internal (gears) were replaced.
    All four shocks are replaced with "Kabli maal".
    Now after getting it back, I was having diesel like performance. Checked with the mechanic and found that the right gears were not found so some "Juggar" was done to fix the 4x4 gear. Basically they have manipulated the gear ratios that needs to be fixed. Per mechanic, he is still looking for the right gears.
    I will bring it at coming IJC's event for expert advice on further work.
    Once I am done with mechanical issues, it is due for a visit to Jameel Ustad for rollcage, auxiliary fuel tank and other minor works.
  18. #77
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    sir, updates?
  19. #78
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Yaar dukh bhari dastaan suna to de hay.
  20. #79
    parapilot's Avatar
    Nov 2006
    Slave Lake
    1,903
    6 Post(s)
    Restoration of Lazzaz -151081
  21. #80
    offroader2323's Avatar
    Jul 2007
    73
    @parapilot...
    kindly guide me about the off road perpormance and relibility of this engine as compared to the diesel 2C one as i myself planning to swap my Suzuki LWB's 2C engine with this 3s one. but i am confused regarding the reliability cause my current set up had never cost me any trouble in the may. even though it gives up after reaching home saftely :-).
