Results 1 to 4 of 4
Thread: Jeep CJ-7 Wrangler with Coil Springs
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default Jeep CJ-7 Wrangler with Coil Springs
    I have not been able to locate my Coil CJ thread so here goes again. I never got to test drive it but hopefully one of these days....
    I finally managed to track one of these down. Its a CJ7 converted to TJ Wrangler shape with leaf springs replaced by Toyota Landcruiser 70 series coil spring suspension. The Jeep is owned by mechanic Imran Ustad who spent a painful amount of time getting the suspension geometry right. I am told that the Jeep has very good handling but the conversion was done and redone several times with bits of a TLC frame welded onto the extended CJ7 frame. I believe this Jeep was completed sometime back in 2002/03.
    Jeep CJ-7 Wrangler with Coil Springs - filephp?id2499
    Jeep CJ-7 Wrangler with Coil Springs - filephp?id2501
    Jeep CJ-7 Wrangler with Coil Springs - filephp?id2502
    Jeep CJ-7 Wrangler with Coil Springs - filephp?id2503
    Jeep CJ-7 Wrangler with Coil Springs - filephp?id2500
    doubletrouble's Avatar
    Mar 2005
    27
    1,574
    looks real nice...
    Mar 2005
    27
    1,574
    btw anyway of finding MUTT M151
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Quote Originally Posted by doubletrouble View Post
    Go on to GT road toward Tarnol, much before the railway line you will see a yard on your left below. Can't miss it, especially if you are being driven there.
    Malik & Ch sb have quite a few of them waiting to be restored.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
