Results 1 to 2 of 2
Thread: TLC Water Spill Help Reqd
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Default TLC Water Spill Help Reqd
    I just bought Toyota LC 1KZTE Manual Transmission.
    Problem
    • Radiator refill bottle topped up to Full Mark
    • Engine started & when Temperature Gauge shows Engine has warmed up i.e. Gauge Needle at 0 Degree Water starts draining from the Refill bottle drain pipe & refill bottle gets empty.
    • The Radiator remains filled not till top but a little lower & water is seen in it.
    • If I donot fill water in refill bottle & only top up the Radiator then Water also drains from drain pipe & level gets a little lower & water is seen in it.
    • BTW the Temperature Needle remains at 0 deg & does not climb up.
    • I changed the Radiator Cap but problem is same.
    The Coolant should go into the radiator not come out.
    Help reqd
    HamzahF's Avatar
    Mar 2008
    28
    210
    8 Post(s)
    @baigaqeel
    As you have said in your post, under normal operation, water should circulate within the radiator, water body and through the cylinder block. If its coming out the drain pipe, it means that there is a pressure buildup that is making it go the other way round. A possible source of this pressure is a bad head. What happens is that the head face, the part that rests on top of the cylinder block gets uneven and the pressure from the cylinder compression leaks into the water circulating around the cylinder walls, and it is this pressure that pushes water out your drain pipe. Saw the same problem with a 22RE TLC and that required the head to be shaved a little to make it even and then fitted back on with a thicker gasket to keep the cylinder volume the same. The 1KZ is a powerful motor but it has a reputation for getting bad heads. Have a guy check it out and i am sure it will narrow down to this.
    Flat six flattening things out!
