Results 1 to 9 of 9
Thread: Suggestion required from Mutt experts
    NoWorNeVeR's Avatar
    Dec 2005
    36
    832
    4 Post(s)
    Default Suggestion required from Mutt experts
    Bros,
    i am fed up with My MUTTS stock transmission and differential noise . i am running a 3c Turbo engine in it.
    Please suggest a good transmission (With 4X4) and ways to eliminate differential noise from it.
    (plz reply quick as my MUTT is already in workshop and i need to get is set so that i can proceed to northern areas soon.
    looking forward for quick feed back
    regards
    B all U can B
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Is it just the noise that bothers you or is the transmission giving you troubles?
    You can put in Mercedes 220D diffs in it, i'm surprised your mechanic has not already suggested that.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    NoWorNeVeR's Avatar
    Dec 2005
    36
    832
    4 Post(s)
    @sarmadqureshi
    Bro, both bothering me.
    Can you plz eleborate Merc E-220 diffs. I mean its a car n .... are they strong enough coz i am a hard core driver?
    And secondly is it a tube system of proper differentials as stocks ?
    Thankx
    B all U can B
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    1st Option - Pajero Gen 1 has IFS Diffs. Thats what I have used for both front and back. Need alot of alteration.
    2nd Option - MB E220 diffs are independent.
    3rd Option - alternation of any suitable tube diff into an independent axle diff.
    Lots of option, depending on what you are willing to experiment and your patience level with the mechanic of explaining how to do it :-)
    AM General Jeep M825 MUTT | 3 C Turbo Diesel
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Mind you once you start playing with the diff then you might as well re-do the entire drivetrain such as: front & rear axles, 4x4 and rear shaft, gearbox, cross / cv joints, cv hubs, supsension mod due to extra weight, and the list goes on :-p
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    If you change your gearbox then be careful on the front diff alignment, as all other gearboxes would have their 4x4 shafts from the side, hence woul d need to attach tube on one side of the diff to align the 4x4 shaft. i.e. the front diff would need to be on the side. So you are only left with Option 1 & 3 if you decide to change your gearbox.
    NoWorNeVeR's Avatar
    Dec 2005
    36
    832
    4 Post(s)
    thankx Ali :-)
    B all U can B
    bobby9191's Avatar
    Aug 2009
    40
    143
    if it is posiable that we can switch the diffs ...i mean rear diffs with front.... that might reduce the noise... ...it is very dificult to make modification /changes in Mutt.... so its better to have jimmney or mimi pajero if u realy fedup.... i dont suggest u to make it Change .... otherwise it will be the bigest Punga of ur life.
    NoWorNeVeR's Avatar
    Dec 2005
    36
    832
    4 Post(s)
    @bobby3131
    yes bro its possible. Both rear and front differentails of MUTT are the same
    I had done that last year
    B all U can B
