Results 1 to 6 of 6
Thread: need roof rack for cj7
    tmkhan77's Avatar
    Mar 2007
    37
    338
    Default need roof rack for cj7
    Any body help me in finding roof cage for hard top cj 7 .which is easily remove when i change the jeep from hard top to soft top.Location is in karachi.where do I find or fabricate it my self
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Quote Originally Posted by tmkhan77 View Post
    Perhaps this picture might help....
    need roof rack for cj7 - 100736 need roof rack for cj7 34006need roof rack for cj7 - 100736
    Pakwatan Explorer
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Probably best to fabricate one for yourself. You can probably pick up some elements from thread for the roofrack Doc Ehsan Kiani did for my CJ7 sometime back. Though I notice that there are no fully finished pics here.
    https://www.pakwheels.com/forums/4x4...ro#post1754131
    Some points to note are:
    - the hard-top usually sits a few inches higher than the soft-top
    - the rear mounts can typically be on the rear bumper or on the body just above the rear brake lights
    - The front mounts would invariably have to be on the side of the windshield frame/pillars.
    - Fabricating your own would allow you to pick the finer design elements from here and there as per your choice and vehicle needs.
    tmkhan77's Avatar
    Mar 2007
    37
    338
    Thanking you Mr Sajjad and Mr kiani
    I got the idea and now starts working on it basically I need it urgently coz i have plan for pakistan tour in july mid .are the bolt which u used in the rear support are working fine while loaded?
    Thanks again
    tariq
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    The entire structure is very solid (touch wood). Since the roof rack was made a hardtop has been put on and we just modified the height of the rack to place on the hardtop and I was again impressed with how solid it sits (touch wood again).
    Its not really a difficult or challenging fabrication, if you can find someone with experience they can probably do it quite quickly.
    BTW: If I was to do it again, the some things I would perhaps bring the overall design (specially the top rail) slightly closer to the rack on the Jeep Dakar Concept (below). The mounting points and the basics would however stay the same.
    need roof rack for cj7 - jheep dakar baltimore 06
    tmkhan77's Avatar
    Mar 2007
    37
    338
    you are right i also do some changes in the style and post the pictures when it is ready
