Results 1 to 7 of 7
Thread: differential lock vs traction control
    a_n_memon88's Avatar
    Jun 2010
    28
    1,872
    44 Post(s)
    18 Thread(s)
    Default differential lock vs traction control
    first I heard about traction control and then i heard about differential lock both are used in slipery conditions. I was wondering that what is the difference between two. please help me
    HasaanIqbal's Avatar
    Mar 2009
    Khewra
    43
    74
    To my Understanding is both are used for the same purpose but with different methodology
    Diff Lock : More or less it is a non computer based locking of wheels on the same axis/ axle ( either front or rear or both ) . There are no sensors involved . Vehicles with diff locks are suspected to damage on a bend as then the axles are overloaded.
    Traction controls : It is a sensor based power supply to wheels ( essentially thru use a computer, but fluidised coupling tech is also used in some older versions ). Like wheel spin is avoided at all times by reducing the power being supplied to the wheel
    Simply speaking , high tech vehicles are furnished with traction control which is centralised and mostly in vehicles with independant power drives .( it acts like a fluid coupling but is automatically controlled thru motion sensors and a plc) Traction control vehicles are very usefull as dependance on quality of driver skills are greatly reduced . Honda CRV has it and it is operative in all conditions. More so , driving in motorway , up the kallar kahar mountains , on a bend , traction control will come into play and provide power to a specific wheel as per requirement . BUT TRACTION CONTROL has its limits . Hardcore offroading may not prove to be as easy with traction control as with a diff lock option
    turbolover's Avatar
    Oct 2006
    41
    1,099
    Quote Originally Posted by a_n_memon88 View Post
    A lot of difference
    Traction control prevents wheels from making a locking while brakes are applied with full force. If the wheels lock up...u loose steering control and resultantly u bang into the car in front. In a car with traction contol feature, u can fearlessly apply brakes with full force and even steer the car. You are not going to loose the steering control. Its a brake related thing that is more useful while driving on road.
    Diff locks adds traction to a vehicle off road. The engine power is equally distributed to all four wheels through drive train (transfer case, prop shafts, axles). So it is a drive train related thing. If diffrentials are open (unlocked) the power to each wheel can vary to compensate for different driving condition. E.g. during a turn, inner wheels cover shorter distance than the outer wheels, so differential, by default, is doing the compensation by sending less drive to inner wheels and driving the outer wheels more ... that why its called differential. Now if u lock the differential, e.g lock the rear axle, the rear axle will loose it default function and will act as a single rod type axle of a toy car. What u achieve:- With a locked differential, if you get one tyre stuck, the other will retain the grip and let u drive out. A car with its diff locked should only be driven off road, as the differential can't compensate variable power during a turn, it will result in excessive tire wear or u may even end up winding up your differetials.
    Most 4x4s only have center diff locks. Only few comes with rear axle diff locks.
    Truckin' Time with a Surf, because life is too short to fix Land Rovers
    punk1's Avatar
    Nov 2005
    Peshawar
    28
    2,090
    25 Post(s)
    5 Thread(s)
    @ above
    traction control is not used for braking.
    ur tolking abut ABS the alow not to slip ur TYRes
    TRANCTION cntrol allows u to accelarate ur car as fast as u cn without WHEELs SPIN
    READ both again.
    ull get ur answer cleared
    Site Banned Follow
    BackToCivicFaiez's Avatar
    Jun 2010
    6,164
    11 Post(s)
    4 Thread(s)
    Traction Control :
    It uses the brakes to make sure they dont skid while accelerating, to avoid wheel spin....this gives more grip/traction....this gives better handling in straight line and turns and slipery conditions...
    Differential lock
    : This has nothing to do wid grip in a straight line....this has everything to do with the axels while the car is being steered.....
    Here is a video to teach u how this works, since its hard to explain using words....:
    thank u
    Site Banned Follow
    Jun 2010
    6,164
    11 Post(s)
    4 Thread(s)
    its a long video.....but watch it complete...its interesting and informative....
    turbolover's Avatar
    Oct 2006
    41
    1,099
    Quote Originally Posted by punk1 View Post
    @ above
    READ both again.
    Thanx for correcting. yeah ur r rite, Traction control works at the opposite end of the scale from ABS. ABS is for braking while Traction Control is for acceleration. Just googled: ABS and traction control operate similarly. In fact, the ABS control unit is the basic "building block" for traction control and stability control. By adding modules and sensors, the system can be expanded to include these newer technologies
    Traction Control
