Results 1 to 7 of 7
Thread: 4 X 4 Help needed
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    Default 4 X 4 Help needed
    Aoa
    All 4 x 4 wheelers, i am new to suvs.Can some one explain the gears of prado. When the small stick is in low/ N or my car does not reverse, even with the 4x4 engaged? please some 1 explain how to use both sticks togather.
    4 X 4 Help needed -102234 4 X 4 Help needed -102235
    Will appretiate detailed instructions as i am new to prado
    BEST THINGS IN LIFE R NEVER FREE
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    @janj........ already read it nothing helped
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow
    Quote Originally Posted by kasaas View Post
    Read it again might help you, small lever (N) position is to tow your vehicle.
    When the position of small lever is (N) stands for Neutral the vehicle will not going to move forward or reverse by putting it in D or R.
    (Neutral) Not engaged on either side; not taking part with or assisting either of two or more.
    If you still need help do visit & ill show you practical.
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    THANX! for normal drive shud i keep it on lo or hi?
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow
    Keep in HIGH -H- all time, use (L) in the following situation
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    Thanx! fully understood
