Results 1 to 6 of 6
Thread: advice regarding gear and diff
    tmkhan77's Avatar
    Mar 2007
    37
    338
    Default advice regarding gear and diff
    I am using cj7 with 13B engine but i didnt satisfied with its performance .The jeep goes max on 110 km/hr speed .I think the gear and diff doesnt match with it .please advice what is the best combination of 13B engine which Gear and diff should I used .Secondly may I increase the performance of this engine by installing turbo in it .what is the effect on fuel consumption.
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    What tyre size r u using? Also the type of rims? And lastly, which r the current gear and diffs?
    Turbo will increase fuel efficiency and top speed as well.
    tmkhan77's Avatar
    Mar 2007
    37
    338
    i use 31" tyre and didnt have any idea about the current gear .basically i purchased this ride 4 month before .i done pakistan tour on it with out any single complain .only one thing i notice which is its speed.now i have an option of engine swap to 2L or 3L with hilux gear and diff or use right gear and diff with 13 B .What is your idea about 2L or 3L if you compare it with 13 B
    tmkhan77's Avatar
    Mar 2007
    37
    338
    any one please advice
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by tmkhan77 View Post
    For God's sake, don't put in a 2L or 3L by replacing the excellent 13B. Add a turbo, but you must find out what gear and diff you are using first. Go to a mechanic, they should be able to tell you. You are right, your problem will most likely be a bad combination of your powertrain.
    Rao.
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    tmkhan77's Avatar
    Mar 2007
    37
    338
    is turbo for 13 B is easilly avaiable and what is the best combination of gear and diff for 13 B
