Results 1 to 17 of 17
Thread: Advice regarding Nissan safari engine 2001 model
    iftikharraheel's Avatar
    Nov 2007
    Select City
    46
    155
    Default Advice regarding Nissan safari engine 2001 model
    I am using Nissan safari 2001 model 3 door with RD 28 eti intercooler 6 cylinder engine.I use the jeep for offloading also but not satisfied with it's offloading abilities because of less torque.my engine needs overhauling.I want to change the engine.what will be the best option.either to keep the same engine or some heavy Nissan safari engine.I rarely do offloading.if I buy a kabli rd28eti engine,then where to buy it and the approximate cost of this engine.
    virtual_law's Avatar
    Jun 2005
    392
    Did you buy any chance blow one of the engine cylinders of that RD 28?
    spiderman's Avatar
    Feb 2005
    9,667
    52 Post(s)
    7 Thread(s)
    Nov 2007
    Select City
    46
    155
    Due to the mistake of some local mechanic,my engine got damaged
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    You can put in a TD42 Nissan it costs around 200k
    RD28 is rarely available and costs around 100k
    Overhaul will cost around 70k and solely depends on the kharadiya and mechanic who are doing it.
    Keep a cool head and wear seatbelts!
    Nov 2007
    Select City
    46
    155
    Thanks for ur advice.what about 3.0 ddti safari engine.any chances of availability of 4.8 l version in Shoba or bilal ganj.
    hasan.nqv's Avatar
    Jul 2010
    Rawalpindi
    296
    2 Post(s)
    put a big block V8 from an american GMC......6.5ltr......suhaib kiani of IJC has it....... enjoy offroading then =)
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    The RD28 is a good engine, but from experience, if you mess it up its quite difficult to guarantee that you would get it back in shape out here as both experience and parts are lacking.
    I would think you could possibly find a replacement RD2800 engine for under 50K these days given that its an out of market engine which is nevertheless available mostly kabli pieces out of Nissan sedans albeit older models not the 2001 efi one you have. I may be wrong on the price though but you should check to see if you can get a good deal.
    The V8 Hasan mentioned would be overkill for the 3 door anyways but given its a newer car I am sure the best option is to possibly get a good newer Nissan diesel engine from Quetta or Karachi, though it may take you a while to find one.
    "If YOU don't believe in what you're doing it'll never work."
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    The RD28 is a great engine. It can't go wrong unless messed around with.
    Which engine to swap it with is based on which transmission does it have?
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    The 4.8 VTC you are referring to will be very difficult to attain in Pakistan. I do however feel that it is the best petrol engine these days. If you could find one, you would be very lucky.
    Rao.
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    Nov 2007
    Select City
    46
    155
    Rd28 with manual transmission 5 forward
  12. #12
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Well, as in most parts of the world, in Pakistan there is always merit in making the switch to a Toyota engine..... why do I hate saying such things
    Particularly in this case, you have the successful recent precedent of the Nissan Shabab Dragon documented by some crazy fanatic on the IJC Forum : Islamabad Jeep Club • View topic - Operation Safari 1FZ-FE : The Dragon's New Bride
    ....and I do feel that the market value and marketability of a 2001 Nissan Patrol may actually increase somewhat if it has a Toyota powerplant
  13. #13
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Quote Originally Posted by iftikharraheel View Post
    If you put in a TD42 it will loose the acceleration edge and will loose a little bit of torque as well. The TD42 is a simple reliable yet inefficient engine. You do things to it that one can only imagine and yet it will run like a dream. Lasts quite long as well. A properly maintained engine can go upto 300,000 kms.
    I think your best option is to get that RD28ETi fixed and go with it. Swapping a engine is one pain you don't want to take, there are multiple things that can go wrong at any point. Initially it seems easy but when you get into it you realize that you were better off with the original one. If you swap the engine you'll need to change the transmission as well because its no good with high power engines.
    The best option in terms of a swap is a Nissan ZD30DDTi with a S50B transmission. The transmission is bolt on and you will just need to replace the engine mounts as this setup comes standard in Y61 Patrols/Safaris. I have rarely come across ZD30 is Pakistan though.
  14. #14
    Nov 2007
    Select City
    46
    155
    I think the best option is just to get this rd28 fixed.engine swapping is not a good option.
  15. #15
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Well it depends, if the patrol is disposable and you're aim is not resale to get the most of your money back you can put in a V8.
    If you need parts for the RD28ETi i can hook you up with the Nissan Parts Dealer in Lahore.
  16. #16
    Nov 2007
    Select City
    46
    155
    If I want to put v8 in it then how much modification required.is the present safari suspension ll be compatible with v8.which v8 you prefer to put in this safari.also kindly give me the contact no of Nissan safari dealer Lahore.
  17. #17
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    Raheel did u replace the engine ?
    he who seeks shall find or he who finds shall seek
