Results 1 to 11 of 11
Thread: OK NOW JEEP LOVERS.!
    vackoo's Avatar
    Nov 2004
    28
    1,881
    6 Post(s)
    Default OK NOW JEEP LOVERS.!
    Jeep Wrangler Rubicon
    The Rubicon name isn't just for a Class 10 off-road trail anymore – it's also what the Jeep brand is calling their ultimate off-road rig. Jeep owners travel from around the world to test their four-wheeling skills on the Rubicon Trail in Northern California, considered one of the most demanding 22 miles of off-highway driving in America. Jeep engineers have designed the most capable Wrangler model ever – and true Jeep owners will realize exactly what that means.
    While its beefy off-road tires and diamond plate sill protectors hint at the tremendous capability of the Jeep Wrangler Rubicon, it's the underpinnings that make it worthy of wearing the Rubicon name. On sale in summer 2002, the Jeep Wrangler Rubicon model features locking front and rear differentials, front and rear Dana model 44 axles and a 4:1 low range transfer case in response to the most demanding off-road enthusiasts.
    The Jeep Wrangler Rubicon has locking differentials that can be driver actuated when the transfer case is in low range and the vehicle speed is less than 10 miles per hour. A dash-mounted rocker switch allows the driver to lock the rear axle and toggle the front axle locker on and off for improved maneuvering. A pneumatic pump runs at just five pounds per square inch for a more reliable and quieter system than is available in the aftermarket. This mechanically locks the axle shafts together to drive all four wheels at the same speed. When not locked, the rear axle has a torque-sensing limited slip feature to provide better traction and handling on-road. Dana model 44 axles with 4.10:1 ratios for both front and rear provide the durability and strength needed for extreme off-road driving.
    The Jeep Wrangler Rubicon features unique exterior design cues and will be available in Inca Gold as well as the other nine Wrangler exterior colors. A 22-inch long 'Rubicon' graphic is prominently placed on each side of the hood. Heavy gauge diamond plate sill guards are bolted to the body sides to protect rocker panels from damage in off-road driving.
    General specifications
    Record last updated Before 12 / 01 / 2004
    Country of origin United States
    Year of introduction 2003
    Numbers built N/A
    Body design N/A
    Weight 1688 kilo / 3721.4 lbs
    Drivetrain
    Engine PowerTech Straight 6
    Engine Location Front , longitudinally mounted
    Displacement 3.956 liter / 241.4 cu in
    Valvetrain 2 valves / cylinder, OHV
    Fuel feed N/A
    Aspiration Naturally Aspirated
    Gearbox NVG 3550 5 speed Manual
    Drive All wheel drive
    Performance figures
    Power 190 bhp / 142 KW @ 4600 rpm
    Torque 319 Nm / 235 ft lbs @ 3200 rpm
    BHP/Liter 48 bhp / liter
    Power to weight ratio 0.11 bhp / kg
    Top Speed N/A
    0-60 mph Acceleration N/A
    OK NOW JEEP LOVERS! -472331
    OK NOW JEEP LOVERS! -472332
    OK NOW JEEP LOVERS! -472333
    OK NOW JEEP LOVERS! -472334
    OK NOW JEEP LOVERS! -472335
    OK NOW JEEP LOVERS! -472336
    I Love My Honda..!
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    OK NOW JEEP LOVERS! -635482
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    toofast's Avatar
    Sep 2004
    Chizhou
    18,163
    31 Post(s)
    Even if you are on the right track, you will get run over if you just sit there.
    amjadch's Avatar
    Aug 2004
    46
    462
    Good one, nice photos.
    khan4ever's Avatar
    May 2005
    34
    2,752
    great pics (y)
    Bimmmmeeeer 4 Life
    Shergill's Avatar
    Feb 2006
    Chandigarh, Punjab
    45
    737
    More jeep pictures
    OK NOW JEEP LOVERS! -637379
    OK NOW JEEP LOVERS! -637380
    OK NOW JEEP LOVERS! -637381
    Upwards Onwards, when the going gets tough the Tough gets going.
    ranasrana's Avatar
    Mar 2006
    54
    342
    LET ME ADD SOME MORE 4 x 4´s FOR THE FANS....
    OK NOW JEEP LOVERS! -637727
    OK NOW JEEP LOVERS! -637728
    OK NOW JEEP LOVERS! -637729
    OK NOW JEEP LOVERS! -637730
    OK NOW JEEP LOVERS! -637731
    RANA
    ranasrana's Avatar
    Mar 2006
    54
    342
    AND SOME MORE
    [img]
    images/forums/2006/4/2/30_1720480_1229200545457pm_BYP_PakWheels(com).jpg[/img]
    OK NOW JEEP LOVERS! -637732
    OK NOW JEEP LOVERS! -637733
    OK NOW JEEP LOVERS! -637734
    OK NOW JEEP LOVERS! -637735
    RANA
    ranasrana's Avatar
    Mar 2006
    54
    342
    AND SOME MORE..
    OK NOW JEEP LOVERS! -637737
    OK NOW JEEP LOVERS! -637738
    OK NOW JEEP LOVERS! -637739
    OK NOW JEEP LOVERS! -637740
    OK NOW JEEP LOVERS! -637741
    RANA
    ranasrana's Avatar
    Mar 2006
    54
    342
    MORE......
    OK NOW JEEP LOVERS! -637742
    OK NOW JEEP LOVERS! -637743
    OK NOW JEEP LOVERS! -637744
    OK NOW JEEP LOVERS! -637745
    OK NOW JEEP LOVERS! -637746
    RANA
    SilentDeath's Avatar
    Jun 2005
    30
    1,305
    nice pics :-)
    Hell was Full So I Came Back..!!!!
