Results 1 to 4 of 4
Thread: M151 Mutt - Engine help
    AmarAli's Avatar
    Oct 2010
    21
    Default M151 Mutt - Engine help
    Salam,
    I'm starting a M151 mutt project ... i wont be using it offroad alot so i am disabling the 4x4 system and keeping it RWD. My question is ... I want to put a petrol engine into it and swap out the original engine it comes with.
    Any suggestions for possible engines + transmissions that would go well with this car in terms of weight, power, fuel efficiency and maintenance?
    I was considering going with a 1JZ-GE but i don't know how reliable the engine is and how is it to maintain.
    Any help would be great thanks!
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    I have seen few rigs with Toyota 3s motor in it and seen their performance too good. But this need an expert mechanic as 3s is a sort of advanced engine and needs alot of care.
    Why not you keep its stock motor - believe me its the best as i have kept a stock mutt and restored it to its original specs.
    tk care
    aisheikh's Avatar
    Mar 2005
    36
    697
    2 Post(s)
    Quote Originally Posted by AmarAli View Post
    Salam,
    I have a friend who can completely restore your engine and gearbox to stock specs, with working 4x4. It will be cheaper and more reliable. The stock engine can give you 9 KM/ Liter. Its not bad considering the engine is 2.4 Liters.
    AM General Jeep M825 MUTT | 3 C Turbo Diesel
    ulalam's Avatar
    Jan 2011
    78
    Brother I can provide you some parts like lights, dash board gauges, switch lighting (i have both touch type and leg type), kit carburetor, black out light etc. You can contact me at my cell 033 444 34560 or ulalam60@gmail.com
Tags for this Thread
