Results 1 to 2 of 2
Thread: Specs For All Toyota Turbos
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Default Specs For All Toyota Turbos
    I recently came about a file containing all Part Numbers and Specs all Toyota Turbo's. It also has a list which is to identify which engine has which turbo. Also it has the the specs for the Turbine and Compressor.
    I have converted the file into Jpegs and have attached them.
    Specs For All Toyota Turbos - ToyotaTurbos 001Specs For All Toyota Turbos - ToyotaTurbos 002Specs For All Toyota Turbos - ToyotaTurbos 003Specs For All Toyota Turbos - ToyotaTurbos 004Specs For All Toyota Turbos - ToyotaTurbos 005Specs For All Toyota Turbos - ToyotaTurbos 006Specs For All Toyota Turbos - ToyotaTurbos 007Specs For All Toyota Turbos - ToyotaTurbos 008Specs For All Toyota Turbos - ToyotaTurbos 009Specs For All Toyota Turbos - ToyotaTurbos 010Specs For All Toyota Turbos - ToyotaTurbos 011Specs For All Toyota Turbos - ToyotaTurbos 012Specs For All Toyota Turbos - ToyotaTurbos 013Specs For All Toyota Turbos - ToyotaTurbos 014Specs For All Toyota Turbos - ToyotaTurbos 015Specs For All Toyota Turbos - ToyotaTurbos 016Specs For All Toyota Turbos - ToyotaTurbos 017Specs For All Toyota Turbos - ToyotaTurbos 018Specs For All Toyota Turbos - ToyotaTurbos 019Specs For All Toyota Turbos - ToyotaTurbos 020Specs For All Toyota Turbos - ToyotaTurbos 021Specs For All Toyota Turbos - ToyotaTurbos 022Specs For All Toyota Turbos - ToyotaTurbos 023Specs For All Toyota Turbos - ToyotaTurbos 024Specs For All Toyota Turbos - ToyotaTurbos 025Specs For All Toyota Turbos - ToyotaTurbos 026Specs For All Toyota Turbos - ToyotaTurbos 027Specs For All Toyota Turbos - ToyotaTurbos 028Specs For All Toyota Turbos - ToyotaTurbos 029Specs For All Toyota Turbos - ToyotaTurbos 030Specs For All Toyota Turbos - ToyotaTurbos 031Specs For All Toyota Turbos - ToyotaTurbos 032Specs For All Toyota Turbos - ToyotaTurbos 033
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Thumbs up
    cool post!
    Thanks for sharing!
    "If YOU don't believe in what you're doing it'll never work."
