Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By digitalfantasy1
Thread: Pajero 1997 4M40 Fuel Injector Pump Tuning, HELP :/
    usmanraufraja's Avatar
    Feb 2009
    31
    177
    Default Pajero 1997 4M40 Fuel Injector Pump Tuning, HELP :/
    Hello all,
    I am getting this issue of variable rpm when the gear is in neutral or parking position, however there is no issue in starting or driving the car and the current mileage is 79000KM. I contacted the local Mitsubishi service center and they said its a problem of fuel injector pump and need to be replaced as there is no facility of tuning it in Pakistan, then i came to know that i wont get the new on but a KABULI one for Rs.48K, tell me what to do, please help!
    Regards
    Usman
    digitalfantasy1's Avatar
    Dec 2008
    39
    76
    dude if u r talking about the diesel pump .... i just got my pump replaced with a kabuli 1 and also put new noosels for 10K.
    Feb 2009
    31
    177
    yea the diesel injector pump, broooo, tell me the place to get it from if it is this cheap! and tell me if it was for 4M40
    Dec 2008
    39
    76
    yes man mine is also a 4m40 pajero exceed 1996. in karachi there is a huge market for diesel pumps in garden area, dont know bout islamabad though.
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    An electronic diesel pump will cost you an arm and a leg, a mechanical pump should be in the 10-12k range. Depends what your 4M40 is running. As I understand, I think both electronic and mechanical pumps came with 4M40s depending on model.
    MMC
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    Feb 2009
    31
    177
    :O, mine is an EFI so its electronic right?
