Results 1 to 3 of 3
Thread: Help!!!!
    Mallick1's Avatar
    Dec 2010
    Abbotabad
    35
    Default Help!!!!
    Yesterday I had the wheel allignment done on my Jimny and crossed the wheels and after that that the ride has gone wooly. The whole car rolls sideways like a cradle and when I brake, it rolls back and forth sounds funny but this is the problem with it. Btw I am using Bridgestone 205R15 on it with 26psi on front and rear. Any idea how to cure this ?
    a dual 2.0vvti just makes a 1.3 i-vtec lok sad
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Take it back to the guy who did the alignment and tell him what the issue is, tell him to check;
    The balance on all wheels, re-balance if required.
    Check all tires, in and out and see if any walls have given way.
    Check your rims, ideally have them run on the balancing machine without the rubber on and see if they turn a perfect circle (see rim from side) and in a straight line (see rim from behind).
    Do the alignment again.
    If all this doesn't work, put back the wheels the way they were and then check the drive.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    Mallick1's Avatar
    Dec 2010
    Abbotabad
    35
    thanx for the help, will do that
