Results 1 to 10 of 10
Thread: Wagoneer 1983
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Default Wagoneer 1983
    I have seen a reasonable condition wagoneer with a person and have developed some interest in buying it. Its in original condition, painted only from outside. Has 2b diesel engine with original 4 fwd gear and total original mechanically. Original seats, dash board. No AC, no heater. Can someone pls let me know the following.
    1. Is this beautiful beast worth keeping for offroading purposes.
    2. Can i get it's body parts from the local market?
    3. If the original things (mechanical items) needs repair, like brakes, front ends, leaf springs, shafts, crosses, steering assembly, free wheel hubs, than would it be possible to find these things from the local market.
    4. If not, than is there any alternate of like using toyota items in it? Pls specify all above mentioned parts.
    5. Is a 2b engine enough for this heavy weight vehicle? And what would be the diesel consumption?
    Regards
    2fast_to_furious's Avatar
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    though a nice offroader however in Pakistan you will end up like this..
    Wagoneer 1983 -200334
    WhEn ThInGs Go WrOnG, DoN'T Go WiTh ThEm.
    farhan678's Avatar
    Jan 2009
    Rawalpindi
    25
    1,256
    similar to this one?
    Wagoneer 1983 - i115500
    if it is the same, then i see a similar machine daily in sadiqabad area rawalpindi and the person is using it for toe-ing a big generator(or something like it) i think. u can find one in this area too.
    tamoorwazire's Avatar
    Feb 2009
    Attock
    30
    110
    Sallam,
    We have a 78 model wagoneer, but it is very difficult to original parts
    Regards
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Quote Originally Posted by noman8ff View Post
    Regards
    Noman,
    I have kept an 83 wagoneer with a 3B engine for years before my Hilux.
    It was all original, but then we changed the 3 speed gear with a 5 speed gear.
    The parts that you have mentioned are not a big issue. Just check what differentials it runs with and whether they sync perfect with the 2B.
    As for a 2B in that machine, I don't think that it would be an issue, but would also suggest not to expect too much out of it.
    Does this one have a power steering ?
    All in all, it is a hassle to maintain once things start to go bad and when one starts to do alterations, the whole geometry, chemistry and physics start to go bad.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    It has a 4 fwd gear and original power steering.
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Aoa.
    We have had a 1979 Jeep Cherokee for the last 26 years now. We had OEM mechanicals in it initially but in the mid nineties we converted it to all TLC BJ 60 (with 2B) mechanicals (we could not find a broken rear wagoneer axle). Recently we are again rebuilding it with a Big Block V8 and all mechanicals from a Suburban and 37" tires. You can see pictures and details of the rebuild and other older pictures at the IJC forum.To answer your questions.
    YES
    No. You have to dent all the sheet metal. Stuff is available in Quetta though.
    In my opinion, it is very difficult to find spares for the wagoneers. You have to venture in to salvage yards and scavenge for old spares. New spares are not available.
    All Toyota BJ 60 0r 80 Mechanicals.
    Yes it is (but who wont want more power ).
    Thanks
    Ehsan
    irfankhanyousafzai's Avatar
    Sep 2007
    Peshawar
    39
    Default Need Toyota Sprinter 86
    hi guys i need toyota Sprinter 86 in fully Genuine conmdition. i am in peshawer and can manage visiting ISB etc if car is there. but car should be in genuine condition AC working cng fitted.
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @noman8ff
    Well if it is all going to be BJ mechanicals, I suggest you rather buy (BJ) one! On the other hand, if my memory still serves me right, you do have a decent BJ already on your hands????......or mayyyyyyyybe it's the desire to be the king of jugar is kicking in!
    MEN DO IT AT DAKAR!!!
    qwertypoiu's Avatar
    Feb 2007
    29,141
    153 Post(s)
    3 Thread(s)
    i have seen its add on PW looks in good condition
    RIP
