Results 1 to 2 of 2
Thread: Transmission difference b/w FJ 60, 62, HJ 61 and BJ 60's
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Default Transmission difference b/w FJ 60, 62, HJ 61 and BJ 60's
    There is a lot of information available on net about the subject issue but no information on the following.
    I have a stock FJ 62, 3F which is with 4 speed manual transmission. The top speed is good with 3000RPM @ 120 KM/hr. The transmission is H41.
    I just want to ask the following questions,
    1. Can the transmissions of the subject vehicles be changed with each other WITHOUT any cut and weld or bell housing change with each other? Like for any reason, if i want to change the existing transmission, can i just fix the housing of the H42 or H55f with the existing engine?
    2. I know H55F is 5 Fwd but what is the difference between H41 and H42 as both are 4 Fwd?
    3. Also what do we mean by T-Case splines? They are 16 and 19 i think.
    Regards
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    to start with ratio
    Transmission & Transfer Case Ratios (All :1)
    Model Engine Dates Spds 1st 2nd 3rd 4th 5th R Tfrlow
    FJ25? -- -- 4 5.41 3.12 1.77 1 -- 5.44 --
    J30 F 69-75 3 2.757 1.691 1 -- -- 3.676 2.313
    H41 F -- 4 4.925 2.643 1.519 1 -- 4.925 1.992
    H41? B 75-80 4 5.299 2.843 1.634 1 -- 5.299 1.959
    H42 F,B 73-75 4 3.555 2.292 1.41 1 -- 4.271 1.992
    75-80 4 3.555 2.292 1.41 1 -- 4.271 1.959
    81-82 4 3.555 2.292 1.41 1 -- 4.271 2.276
    H55F F,B 83- 5 4.843 2.619 1.516 1 0.845 4.843 1.959/2.276
    H150F HZ -- 5 4.529 2.464 1.49 1 0.881 4.313 2.488
    H151F FZ,HD -- 5 4.081 2.294 1.49 1 0.881 4.313 2.488
    A440F -- 4? -- -- -- - -- -- 2.488
    A442F FZ,HD -- 4 2.95 1.53 1 0.765 -- 2.678 2.488
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
