Results 1 to 6 of 6
Thread: Willys Kamani Shackles
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Default Willys Kamani Shackles
    I need to change the spring shackles (Kamani Jhola) of my M38. Currently it has original C type greasable shackles. New replacement is not avilable. Could any one advice alternate. Where the good quality bushings and H type shackles are available?
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Still looking for advice
    samvaid's Avatar
    May 2010
    39
    562
    65 Post(s)
    7 Thread(s)
    If you are in RWP/ISB area, then you should goto city saddar road, and you shall be executed with a solution, otherwise call Farooq Sb (0333 520-7251), who i am sure can help you out.
    Regards.
    Sam
    Quote Originally Posted by saad_q View Post
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Thanks samvaid, will call him. Is he a parts dealer in Rawalpindi?
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    @saad_q: I am not too well versed with M38 shackles but I understand that one of the IJC members uses the original C shackle with an added brace on the other side, sort of a D as seen in the pic below. Works well from what I know. Do call Farooq as he will have better insight into the matter as a jeep builder/mechanic. All the Best!
    Willys Kamani Shackles - filephp?id12193
    "If YOU don't believe in what you're doing it'll never work."
    azkhan's Avatar
    Mar 2004
    28
    517
    20 Post(s)
    For original bushes check with Taj Autos (jeep parts dealer 051-5564128) but you have to take sample with you.
    //.....Don't bully Korean cars.......//
