I need to change the spring shackles (Kamani Jhola) of my M38. Currently it has original C type greasable shackles. New replacement is not avilable. Could any one advice alternate. Where the good quality bushings and H type shackles are available?
Still looking for advice
If you are in RWP/ISB area, then you should goto city saddar road, and you shall be executed with a solution, otherwise call Farooq Sb (0333 520-7251), who i am sure can help you out.
Regards.
Sam
Thanks samvaid, will call him. Is he a parts dealer in Rawalpindi?
@saad_q: I am not too well versed with M38 shackles but I understand that one of the IJC members uses the original C shackle with an added brace on the other side, sort of a D as seen in the pic below. Works well from what I know. Do call Farooq as he will have better insight into the matter as a jeep builder/mechanic. All the Best!
For original bushes check with Taj Autos (jeep parts dealer 051-5564128) but you have to take sample with you.
