Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 238
Thread: Pre Cholistan Sand Run at Indus
    spiderman's Avatar
    Feb 2005
    9,667
    52 Post(s)
    7 Thread(s)
    Default Pre Cholistan Sand Run at Indus
    today @desertdevil, NN, Untamed, ParaPilot, SuhaibKiani decided to check there vehicles for the upcoming cholistan Rally it was a fun day out with some great runs in the sand
    we assembled at the meeting point at 8am in the morning and then went to the sand run site.
    Pre Cholistan Sand Run at Indus - 206732
    Pre Cholistan Sand Run at Indus - 206733
    VDOs by NN
  2. #101
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    @MitsuMan: Many thanks for the compliments!
    @DeeDee: No lift as yet! We have not put in the twin turbos
    @qwertypoiu: Yes, the suspension needs more work in the short term and lots more cash in the long term! My impression is that sprung setups need position sensing/triple bypass shocks to truly overcome their limitations.... Nevertheless, the sand runs (full vids will come through hopefully) were not as bad as I was dreading they would be.....We need a bit more lift with better bump stops and probably double the shocks with a set of adjustable Ranchos. But although we will tweak things a bit for the rally, from experience, our desi leaf spring suspensions take time and a bit of abuse to settle in for optimal performance.
    Special thanks to Janj, Doc nn and Ali for taking the time to shoot and edit the videos. Also hats off to Rao and Usama for keeping the navigator seat occupied and bearing the cold frontal wind attack!
    "If YOU don't believe in what you're doing it'll never work."
  3. #102
    jazzy77's Avatar
    Jun 2007
    Sialkot
    27
    6,248
    5
    14 Post(s)
    4 Thread(s)
    Excellent runs and coverage !
    www.youtube.com/hassaangr8 - www.flickr.com/hassaanlaeeq - www.facebook.com/photocracyhl
  4. #103
    BMW7Series's Avatar
    Feb 2006
    22
    8,951
    zabardast
    Maa Da Laddlaa Vigar Gaya.... Chevy Aveo Ly K Nikal Gaya.
  5. #104
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204825 Pre Cholistan Sand Run at Indus - 204826 Pre Cholistan Sand Run at Indus - 204827 Pre Cholistan Sand Run at Indus - 204828 Pre Cholistan Sand Run at Indus - 204829
  6. #105
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204830 Pre Cholistan Sand Run at Indus - 204831 Pre Cholistan Sand Run at Indus - 204832 Pre Cholistan Sand Run at Indus - 204833 Pre Cholistan Sand Run at Indus - 204834
  7. #106
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204835 Pre Cholistan Sand Run at Indus - 204836 Pre Cholistan Sand Run at Indus - 204837 Pre Cholistan Sand Run at Indus - 204838 Pre Cholistan Sand Run at Indus - 204839
  8. #107
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204840 Pre Cholistan Sand Run at Indus - 204841 Pre Cholistan Sand Run at Indus - 204842 Pre Cholistan Sand Run at Indus - 204843
  9. #108
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204844 Pre Cholistan Sand Run at Indus - 204845 Pre Cholistan Sand Run at Indus - 204846 Pre Cholistan Sand Run at Indus - 204847 Pre Cholistan Sand Run at Indus - 204848
  10. #109
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204854 Pre Cholistan Sand Run at Indus - 204855 Pre Cholistan Sand Run at Indus - 204856 Pre Cholistan Sand Run at Indus - 204857 Pre Cholistan Sand Run at Indus - 204858
  11. #110
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204859 Pre Cholistan Sand Run at Indus - 204860 Pre Cholistan Sand Run at Indus - 204861 Pre Cholistan Sand Run at Indus - 204862 Pre Cholistan Sand Run at Indus - 204863
  12. #111
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204865 Pre Cholistan Sand Run at Indus - 204866 Pre Cholistan Sand Run at Indus - 204867 Pre Cholistan Sand Run at Indus - 204868 Pre Cholistan Sand Run at Indus - 204869
  13. #112
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Pre Cholistan Sand Run at Indus - 204870 Pre Cholistan Sand Run at Indus - 204871 Pre Cholistan Sand Run at Indus - 204872 Pre Cholistan Sand Run at Indus - 204873 Pre Cholistan Sand Run at Indus - 204874
  14. #113
    ehsankiani's Avatar
    Jan 2005
    Select City
    38
    752
    2 Post(s)
    Great Pictures all around..
    IJC RULES
    Thumbs Up
    Ehsan
  15. #114
    Charged's Avatar
    Apr 2006
    591
    2 Post(s)
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/rcV4T4_WyHc?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rcV4T4_WyHc?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    There ain't no mud deep enough and no mountain high enough when you've got a LAND ROVER
  16. #115
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Lets do it again amigo!!
    MMC
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
  17. #116
    aamir567's Avatar
    Feb 2008
    Select City
    55
    11,953
    26 Post(s)
    7 Thread(s)
    Cool Videos
    -It is always Man behind the Machine.
  18. #117
    Charged's Avatar
    Apr 2006
    591
    2 Post(s)
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/TC5hb3GtTpg?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/TC5hb3GtTpg?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  19. #118
    Charged's Avatar
    Apr 2006
    591
    2 Post(s)
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/OpEFlz-Ar0o?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/OpEFlz-Ar0o?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  20. #119
    nickatnite's Avatar
    Sep 2005
    Chennai
    27,713
    40 Post(s)
    2 Thread(s)
    Cool pics and action.
    Age is a very high price to pay for maturity.
  21. #120
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    @ Charged.... excellent videos bro..
