Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Like Tree1Likes
Thread: FJ40 is riding Jumpy - Solution?
    isiddique's Avatar
    May 2006
    Jehlum
    44
    282
    Default FJ40 is riding Jumpy - Solution?
    Dear Toyota FJ40 enthusiasts – I need your expert opinion as you might have dealt with it at some point. Since I have put in bigger tires (265 with 16 inch Rims) and have lifted the vehicle 2/3 inch. FJ is riding jumpy as if there is no suspension and to the point that something must be done. Some have suggested to go with at least 90’s LandCruiser leafsprings. I am wondering what kind of modification/invasion is required and if such setup is viable option. Also, as a bonus question, if the 90’s LandCruisers Leafsprings are same length/width as compare to stock FJ 40?
    I know nothing except the fact of my ignorance.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comFJ40 is riding Jumpy - Solution? - P
    Regards,
    God grant me the serenity to accept the things I cannot change, courage to change the things I can, and the wisdom to know the difference.
  2. #21
    Cateyez's Avatar
    Apr 2007
    46
    199
    @Isiddique
    ZOR KA JHATKA DHEERAY SAY LAGAY
    There is nothing wrong with your FJ bro.4x4's tend to be jumpy and with leaf-springs on all 4 wheels - the tendency is felt even more. Don't try any "juggars" as it will only ruin your very nice ride.
  3. #22
    Cateyez's Avatar
    Apr 2007
    46
    199
    @Tareen
    Quote:
    <table width="100%" border="0" cellpadding="6" cellspacing="0"> <tbody><tr> <td class="alt2" style="border: 1px inset;"> Originally Posted by isiddique FJ40 is riding Jumpy - Solution? - viewpost
    All the good things in life are either illegal, fattening, expensive or complex .
    </td> </tr> </tbody></table>
    ....or married to someone else!
    TOTALLY AGREE WITH YA BUDDY.
  4. #23
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Another hint for bumpy ride.. check the shackle pin nuts.. they should not be very tight.. the book says hand tight them.. Kamani walon k chotay full zoor laga k tight kar detay hein
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  5. #24
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Quote Originally Posted by akifjanjua View Post
    I don't think so this will be helpful. Tightness of shackle pins have nothing to do with hard ride as the bushes and leaf springs have full movement on the pins even if the pins are fully tight.
    Do put me wise if there is something technical about this issue beyond my learning.
  6. #25
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Noman bhai.. the Manual says hand tight only the shackle pin nuts.. no need to torque full force as mostly done... try it on your cruiser
  7. #26
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Noman bhai..... try it on your cruiser
    Noman Bhai aur agar in case chaltey chaltey kamani nikal aayeee, tau you know whom to send the repair bill to
    Just kidding.... I am sure Akif has tested it on his CJs before recommending it! I have seen shackles on FJs stay put even when the tires are hanging in the air! Pin nuts being too tight could be one possible reason......
    .....but it would still not solve the stiff ride riddle as such! The fundamental reason in my view is a mismatch between the loading capacity of the springs vs vehicle weight. I am quite sure the ride would be much smoother with 6 adults in the car or some heavy weight at the back! If so removing some leafs/pattas would be one solution, although not the ideal way to go!
    "If YOU don't believe in what you're doing it'll never work."
  8. #27
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    for safety reasons.. let me rephrase.. its snug tight with a spanner/rachet
    the idea is not to stand on spanner/rachet to full torque... this is done mostly by chotas with our mistris
  9. #28
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    OK let me try to put my observation forward again.
    The shackle pin is touching the bush from inside of the bush. The leaf spring (shah patta) is touching/ holding the bush from it's outside. Now the bush never moves/ rotates in the shackle/ shah patta. It is the pin which rotates/ moves in the bush. So no matter how much you tighten the nut of the pin, it will never allow both the shackles to touch the leaf spring as the pin has collars to hold the shackles. The nut can only break down or can damage the rings (choori) of the pin.
    For example if the width of the leaf spring is 3 inch, the shackles will never be able to come closer than 3.25 inch (approx), no matter how much pressure you apply on the nut. And this .25 inch gap is exactly covered by the sides of the bush.
    Your understanding on the above is required.
    FJ40 is riding Jumpy - Solution? -210407
  10. #29
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    FJ40 is riding Jumpy - Solution? -210408
  11. #30
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Noman bhai your understanding is absolutely correct.
    I quote the from the body chasis manual of 1980 cruiser.. says 7.5kg-m torque for the pin nuts.. In contrast the torque for the U bolt (rakaab) is 15kg-m.. in absence of torque wrenches.. the modus operandi is brute force.. this is the only reason i say full zoor laga ke tight nai karna
  12. #31
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Ok good enough. By the way did u fix the winch in your cruiser?
  13. #32
    nomi1234's Avatar
    Jun 2009
    1,238
    9 Post(s)
    if aal iz well.. ignore the bumps.. rather enjoy them.. its a short wheel base leaf spung cruiser of the 80's.. that how it rides
    ^^ thats the bottom line
    I've recently upgraded to bigger MTs 32,11.5, 15. and had to do lots of mods to fit them in my jeep. One of the thing was to lift the vehicle. did that with getting some Tarrh in the existing leaf springs and then adding one additional patta all around.
    I didn't go for longer shackles as the mistry said it would interfere with handling at high speeds... adding another patta made the ride quite stiff. I would say about 50% stiffer and bouncier. I am waiting out the spring settling period so hopefully things will get a bit less bumpy..
    but as Akif said, it ain't gonna ride like a coil spring vehicle. not sure if one can ever get use to the 'Jhatkaas'
    I may get Lost But I don't get stuck!
  14. #33
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    I agree with the take it as it is approach to some extent. But in my experience a stiff ride on a CJ5 or 7 or YJ Wrangler does not come close to a stiff ride on an FJ40 Its a whole different level of stiff/rough, making the CJs seem like coil sprung ponies!
    Nevertheless, it seems the thread starter has pretty much accepted his FJ40 as it is, which is probably the best approach for the time being .... and also the consensus view amoungst the FJ40 gurus
  15. #34
    7775889's Avatar
    Mar 2011
    Quetta
    35
    18
    make sure the level of the leafs r same n the front size shold b 6 inchs n rear iz 7...n put sum big size leaf bushes......it helps u alot
  16. #35
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by nomi1234 View Post
    Bro , can you PM me the price of tyres with availability location in this size?
    <<<The Obstacle Is The Path>>>
    1984 BJ41, 1967 FJ40, 1984 BJ61 , 1983 Mutt M825, 1982 CJ5, 1942 Willys
  17. #36
    isiddique's Avatar
    May 2006
    Jehlum
    44
    282
    @ SuhaibKiani bhai "Nevertheless, it seems the thread starter has pretty much accepted his FJ40 as it is, which is probably the best approach for the time being ...."
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
    Actually I am going to try different things as soon I get a chance. I truly believe it is stiffer than it should be, and I can do better here. If nothing else I will learn few things.<o:p></o:p>
    FJ40- An expensive mistress J<o:p></o:p>
  18. #37
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by isiddique View Post
    <o:p></o:p>
    Well, I don't think that the solution to your FJ40's issue, or should we say situation, should be very expensive. For my understanding, can you help me with the following:
    1. Does it run somewhat softer with 3/4 people on board?
    2. Have you ever tried driving it with different shocks or without shocks? If so what did you feel was different?
    3. Do you have access to a decent or half-decent kamani guy near where you are?
  19. #38
    nomi1234's Avatar
    Jun 2009
    1,238
    9 Post(s)
    Quote Originally Posted by machine View Post
    PM'd
