Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By romano
Thread: need help in converting cj7 to wrangler
    shahmirbugti11's Avatar
    May 2011
    8
    Unhappy need help in converting cj7 to wrangler
    can a cj7 easly be converted to wrangler and how much does it cost and wher from pls help
    May 2011
    8
    bump bump
    May 2011
    8
    could use some information so pls
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    @Shahmir: I believe this question has been addressed on the forum a couple of times before. You should try and search the topic and go through results in detail which will give you some interesting perspectives. Here are some threads I remember off hand:
    https://www.pakwheels.com/forums/4x4...tions-required
    Even found a few threads with our Baltoro CJ Wrangler started my brother Ehsan ages ago (it was one of the first conversions back in 2003/4 and things have come a long way since then):
    https://www.pakwheels.com/forums/whe...-detailed-pics
    https://www.pakwheels.com/forums/4x4...-7-wrangler-tj
    There was another thread on a white TJ Wrangler conversion done in Karachi using Jeep parts from Quetta. But I would encourage you to also look at the excellent Black CJ7 restoration done by a Muzaffarabad Jeep Club member....
    Would be happy to answer any specific questions you have after the above....
    Cheers,
    SK
    "If YOU don't believe in what you're doing it'll never work."
    May 2011
    8
    @suhaib kiani thanks for all info but what would u suggest should i go for the body swap or should i restore my cj7 79
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by shahmirbugti11 View Post
    Shahmir,
    It is up to you and depends on what your motivations and preferences are. At the end of the day, both options are very doable and quite likeable. Neither is particularly cheap or easy....
    If I were to do something with a Wrangler look today, I would probably get the front off of a TJ Wrangler (grille, hood, fenders) and mate it to the CJ7 body and doors. I would try and keep the original suspension and diffs of the CJ7 and add a good petrol engine along with a surf gearbox.....
    But in all likelihood I would restore the CJ in its original shape and would just save my money for buying Wrangler accessories (fenders, roll cage, seats, bumpers etc)....
    May 2011
    8
    what about a body swap suhaib bhai
    May 2011
    8
    any one else please
    fobak's Avatar
    Jul 2005
    Select City
    34
    6,166
    5
    92 Post(s)
    27 Thread(s)
    Bro check the link it will help u a lot
    https://www.pakwheels.com/forums/4x4...negade-hardtop
    "Roads ? Where we are going we don't need Roads.....! "
    fobak's Avatar
    Jul 2005
    Select City
    34
    6,166
    5
    92 Post(s)
    27 Thread(s)
    romano's Avatar
    Feb 2007
    46
    1,520
    16 Post(s)
    Pls do not modify yr CJ7. They are ultra rare, and once they are gone...they're gone!
    Its an icon vehicle, and still VERY collectible. Check out PW member AUs CJ7. You will realise that stock is best! Spend yr money on a correct roll bar, and winch. You wont regret it.
    http://groups.google.com.pk/group/vwcop
  12. #12
    May 2011
    8
    thanks for all the help @fobak im thinking about sticking with my cj7 restoration but il need all the information so keep it coming bro
  13. #13
    makb00's Avatar
    Sep 2007
    33
    30
    my advice,,, ill bring a bottle of petrol and we both will go to sultanabad and light it on fire hahahaha,,, how u doin,,, hvnt spoken with u for two days brother,, whats going on???
