Results 1 to 6 of 6
Like Tree3Likes
  • 3 Post By Xulfiqar
Thread: Toyota Landcruiser 1986 HJ60 or BJ60 H2 deisel engine Heating issues
    naveedmerchant's Avatar
    Aug 2006
    51
    113
    Default Toyota Landcruiser 1986 HJ60 or BJ60 H2 deisel engine Heating issues
    I was recently travelling from Karachi to lahore and my lancruiser heated up whenever I stopped the car with AC on under the extreme hot sun and temperature shot to near red top position
    i had even changed engine gasket, replace radiator jali with dolphin jali and still i get same issues. i plan to look at the fan clutch to make sure.
    can anyone suggest any good reliable mechanic in Karachi?
    Also wanted to know from where i can buy genuine landcruiser heavy duty radiator as i suspect i may need new radiator.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Your problem sounds like a classic fan clutch problem.. Good that its a toyota and you can refill it with new silicone fluid.. (toyota sell this fluid as a replacement part)
    check the fan for roaring when starting the engine dead cold, it should roar as the fan clutch is engaged, and once it gets to temperature it should start to couple and move a lot of air (and roar too) fully in sync with engine speed.
    The bimetal spring in the centre should be clean and free of dirt and the radiator fins should be clean as the clutch's bimetal spring needs to get hot and warp out of shape to engage.
    You will usually find the clutch has lost its fluid and is not coupling hard enough or at all for effecient cooling of the engine.
    I just recently redid my mercedes fan clutch here in the US - but in my case I cannot fully open up the clutch like yours - and had to live with baking it in the oven and injecting silicone oil by guessing..
    Aug 2006
    51
    113
    My mechanic says there is leak in the fan clutch and wants me to buy new or another used one once i told him to replace the silicon. i am unsure on his integrity. it would be great if you knew any good reliable mechanic in Karachi which doesnt need supervision
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    be there and supervise, no harm in doing it if you know what Xulfiqar proposed. Or else shershah is wide open take the sample fan compare the spring condition and freeplay ask for possibility of exchange with your unit.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    khan3900's Avatar
    Jan 2006
    39
    9
    the solution to ur BJ60 is that u sell it. LOL
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Brand new replacement clutches are available here. u can find them in KHI as well. USed ones are also easy to find for LC's. If it is leaking, no point in filling silicone based oil again.
    Keep a cool head and wear seatbelts!
