Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By tareen
  • 1 Post By Titanium
Thread: Tyres for FJ40
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Default Tyres for FJ40
    Friends,,,
    Need your help in decision regarding tyres installation in my FJ40. Following are readily available options so i want you to help me decide from them
    1- Yokohama Geolandar A/T 275/65/17 with Japanies 17'' SPIEL Ultra light alloys which i have personally bought from Dubai for my BJ60.
    2- 275/70/16 Bridgestone Blizzak (available with a friend and asking for 50k with rims - normal condition). Pls note that spacers will be required for these as they rub with tie rod ends in extreem turns.
    Please see the pictures below and suggest accordingly.
    Spiel 17 inches with Yokohama Geolandar A/T
    Tyres for FJ40 -263891
    Tyres for FJ40 -263892
    Tyres for FJ40 -263894
    Bridgestone Blizzak with new 16'' tiwan made alloys:
    Tyres for FJ40 -263893
    <<<The Obstacle Is The Path>>>
    1984 BJ41, 1967 FJ40, 1984 BJ61 , 1983 Mutt M825, 1982 CJ5, 1942 Willys
    tareen's Avatar
    Feb 2005
    43
    630
    15 Post(s)
    J40 requires atleast 3.5" or less backspace to fit the wheels without touching any thing other than the hub itself and give maximum turning angle on 31" tires. Bigger / wider the tires, lesser backspace (more -ve offset) is required to keep the tires clear of the steering rod and leaf springs in some cases ;-)
    The firsts set is gorgeous and will look fantastic being a tall one. Does it fit well without the need of spacers? The only rare drawback would be getting 5th tires of the same height in 15 or 16" wheels (I'm assuming the set has 4 pcs as we see normally). And in case need another replacement tire, they are hard to find and expensive.
    Second set has a positive offset so obvious that it will require spacers that will end up being as expensive as another used set of wheels itself. Positive offset is good for higher speeds and cornering and has less to do with our intended application ;-)
    Wassalam
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    @Tareen - yes boss the Yokos fit well without spacers. I had a trial yesterday.
    And its a set of 4 with rims. So you say that lets Install Yokos
    tareen's Avatar
    Feb 2005
    43
    630
    15 Post(s)
    Sorry for the late response, and yes, I think the best option right now is to have Yokos on the vehicle.
    Titanium's Avatar
    Sep 2007
    Dera ismail khan
    42
    513
    5 Post(s)
    The first one is looking good.
    Of all the things i have lost, I miss my MIND the most...
