Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Like Tree9Likes
Thread: Few basic 4X4 questions
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Default Few basic 4X4 questions
    Yesterday for the first time i participated in the 4X4 event being organised by IJC near Simly dam area.
    I took my suzuki LJ50, 2 stroke, 540cc and the result was around 70% against my expectations. There are few questions, which if answered, i shall be able to perform better in future.
    1. On climbing a slippery area, why momentum is required more than power as most of the people were climbing with 4L and 2nd top gear? One yellow colored willys with diesel even did it with 4L/ 3rd gear.
    2. If at all one has to go in 2nd gear with 4L, why not to go in 1st gear with 4H. Will there be any difference in 4L/ 2nd gear and 4H/ 1st gear?
    3. Why not to climb without momentum, with very slow speed (almost zero speed), with 4L and 1st gear having proper mud tyres.
    4. Wider tyres do matter but yesterday most of the easy going vehicles were with the original willys or potohar tyres which are not too wide, hardly 5" in width.
    5. On the climb, on which i failed, in the first attempt, i tried with 4L/ 1st gear but due to no momentum covered only 40% of the climb. On the second attempt, i tried it with 4L/ 2nd gear, i covered 85% of the climb but got stuck there because of loss of power. I had purely on road tyres, unsuitable for slippery terrain. Pls explain this situation and recommend for future.
    Waiting for replies.
  2. #21
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by laparwah View Post
    joys of 2l cannt be achieved on auto hubs , am i right ?
    Sorry sir missed this one earlier... I think 2L can be achieved with auto-hubs if you have 4x4 engager separate from the H/L transfer case shifter. On most of the older Hilux boxes and some TLCs, the 4x4 is engaged via a button (which normally is a PIA) but it allows you to drop vehicle in Low gear without pressing the button...
    2L can also be achieved with manual hubs if you drop the car in 4L but do not engage the hubs at the front. I suppose the front drive-shaft remains engaged in this case....
    "If YOU don't believe in what you're doing it'll never work."
  3. #22
    cougar75's Avatar
    Jun 2007
    Rawalpindi
    41
    235
    Good job and indeed very pertinent querry by noman.
    in my humble understanding it greatly vary vehicle to vehicle but for off roads 4H may not be used unless you are in open runs and its required and meant for better traction, moreover probably the owner or driver is the person who is required to exactly synchronise with his ride to feel what gear is required at what moment depending upon the behaviour of the ride,once i happen to drive FJ70 without 4x4 where one hour prior i remained struck with Hilux LN series with 4L so its mostly with different type of 4x4
  4. #23
    baburawan's Avatar
    Dec 2010
    46
    824
    2 Post(s)
    Quote Originally Posted by cougar75 View Post
    I agree..... 100%
    Be nice to the ppl while going up.. you might meet them on your way down
  5. #24
    cougar75's Avatar
    Jun 2007
    Rawalpindi
    41
    235
    thanks babur
  6. #25
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    on climbing a partial muddy hill in a LR discovery diesel - I just engaged Low range difflock - and you are good to go, climbed the thing like it had claws.
